Sync Speed suddenly dropped
- Sync Speed suddenly dropped
13-09-2009 10:00 AM
Re: Sync Speed suddenly dropped
13-09-2009 10:15 AM
14-09-2009 11:57 AM
Do those line stats change at all if you reboot your router?
14-09-2009 8:10 PM
14-09-2009 8:18 PM
14-09-2009 9:10 PM
Ta
15-09-2009 7:16 AM
15-09-2009 9:01 AM
Have you made any wiring changes at all recently? The line looks normal, but it's definitely synchronising at a lower speed than I would have expected for that length of line.
15-09-2009 9:26 AM
No have not made any changes in the past month.
15-09-2009 9:29 AM
However, I've seen the odd case where a high noise margin (because it means there are less errors present) actually causes an improved sync speed.
If you like, I can ask BT to force it to 9dB and see if that makes any improvement?
15-09-2009 9:40 AM
15-09-2009 9:44 AM
I'll get a fault raised on your account and we'll see where we go from there.
15-09-2009 9:54 AM
Can you power up your router for me when you get back in please? I need to run some checks from this end first before I can get anything raised. I'll need you to keep it turned on too.
15-09-2009 9:56 AM
15-09-2009 9:58 AM
