Sync Speed Dropped
MwEmpire
Sync Speed Dropped
Hi, all has been well for a while but i have noticed my sync speed has dropped from 70Mb to 63Mb,  why does it change ? i thought fibre  stayed more constant. Any help would be appreciated.
Re: Sync Speed Dropped
The last resync you had you synced at a lower speed, this was on the 11th June at 7.14pm. Your line profile is still set to 80Mb/s.
It might be worth doing a soft disconnect and reboot of your modem during daytime hours to see if your sync rate increases.
MwEmpire
Thanks i will give it a try, thanks.
jamesanstee
Im having the same issues except now i have overheating issue with the openreach modem .
Hi James,
I've dropped you a reply in this thread you started.
MwEmpire
Quote from: chrispurvey
Hi Chris, i have tried a reboot of the Modem and my Sync rate has got worse its now 63Mb/s how can i get it to 80Mb/s ?
Fixes: 33
It's rare that anyone would get 80mb exactly (think of that as a maximum possible speed of the technology). Tests are showing a sync speed of 77.5mb at the moment so we'd expect speeds approximate to that.
If it's still as low as 63mb I'd urge you to raise a fault: http://faults.plus.net
Adam
 Adam Walker
