Sync Speed Dropped
- Sync Speed Dropped
Sync Speed Dropped
12-06-2013 11:22 PM
Hi, all has been well for a while but i have noticed my sync speed has dropped from 70Mb to 63Mb, why does it change ? i thought fibre stayed more constant. Any help would be appreciated.
Message 1 of 7
(1,437 Views)
6 REPLIES 6
Re: Sync Speed Dropped
13-06-2013 9:41 AM
The last resync you had you synced at a lower speed, this was on the 11th June at 7.14pm. Your line profile is still set to 80Mb/s.
It might be worth doing a soft disconnect and reboot of your modem during daytime hours to see if your sync rate increases.
Message 2 of 7
(628 Views)
13-06-2013 10:36 PM
Thanks i will give it a try, thanks.
Message 3 of 7
(628 Views)
13-06-2013 10:39 PM
Im having the same issues except now i have overheating issue with the openreach modem .
Message 4 of 7
(628 Views)
14-06-2013 11:32 AM
Hi James,
I've dropped you a reply in this thread you started.
Message 5 of 7
(628 Views)
17-06-2013 9:23 AM
Quote from: chrispurvey Hi there,
Hi Chris, i have tried a reboot of the Modem and my Sync rate has got worse its now 63Mb/s how can i get it to 80Mb/s ?
Message 6 of 7
(628 Views)
18-06-2013 9:20 AM
It's rare that anyone would get 80mb exactly (think of that as a maximum possible speed of the technology). Tests are showing a sync speed of 77.5mb at the moment so we'd expect speeds approximate to that.
If it's still as low as 63mb I'd urge you to raise a fault: http://faults.plus.net
Adam
Adam
Message 7 of 7
(628 Views)
