Sync Speed Down
thedoors27
Sync Speed Down
A few weeks ago I had problems with my electrics in the flat where I live resulting my sync speed go down from 79mb to 77mb. Is there anyway for me to get the 2mb difference back?
xreyuk
Re: Sync Speed Down
Quote from: thedoors27
Wait.
Don't keep disconnecting the modem/router trying to get it to pick up the extra sync, DLM may see these as errors and reduce your sync speed.
Just leave it, and see if DLM raises it at any point, if not, 2Mb isn't a massive difference at those speeds Wink
thedoors27
Re: Sync Speed Down
Ok, I'll keep my eye on it. Fingers crossed it will go back up.
