Sync Rate
- Re: Sync Rate
Sync Rate
20-04-2012 4:51 AM
I am just wondering what the maximum upload sync is you can have on plusnet, i am joining next month which is when my services hopefully get transferred over, i am on llu at the moment will my sync be the same as i am getting now both up and down?.
Message 1 of 6
(1,132 Views)
5 REPLIES 5
Re: Sync Rate
20-04-2012 9:33 AM
Welcome to the forum tomxlisa
What D/L and U/L speeds are you currently getting?
Message 2 of 6
(328 Views)
Re: Sync Rate
20-04-2012 11:35 AM
If you could answer Strat's question that'd be very helpful, though it looks like we're moving you onto ADSL2+ with a capped upstream at 448kbit/s. Don't worry though, we'll be able to uncap that and it'll only take 24 hours and it won't cost you anything.
Message 3 of 6
(328 Views)
Re: Sync Rate
20-04-2012 3:58 PM
My current sync is this, but i am hoping i would get more, as i used to sync at nearly 20mb but for some reason it went down, and sky say they cant get it back up at 20mb.
DownStream Connection Speed 16790 kbps
UpStream Connection Speed 1157 kbps
Message 4 of 6
(328 Views)
Re: Sync Rate
20-04-2012 4:19 PM
I suspect you'll get similar once you're connected to our service (and we've uncapped the upload )
Message 5 of 6
(328 Views)
Re: Sync Rate
20-04-2012 4:27 PM
Yeah, just hopefully more to the 20mb that i used to get, that would be nice.
Message 6 of 6
(328 Views)
