Switching to BT HUB 6 help!
FIXED- Subscribe to RSS Feed
- Switching to BT HUB 6 help!
17-08-2020 1:42 PM
I’m attempting to change over from the Plusnet router which is shocking to be honest and wishing I’d stayed with Sky but here I am.
The problem I have is that I don’t have a computer, only an iPad, so cannot connect an Ethernet directly to the router. Is there a genius who can guide me through the process please?
Fixed! Go to the fix.
Re: Switching to BT HUB 6 help!
17-08-2020 2:57 PM
Assuming your iPad is 'seeing' your new router via Wifi, if you type 192.168.1.254 into your browser you should be able to log into the router using the Admin password, which will let you access: Home>advanced settings>broadband, where you can input your broadband username (<username>@plusdsl.net) and Plusnet account password.
You probably need to save the changes (hard to remember - only had to do it once!)
17-08-2020 3:08 PM
17-08-2020 3:13 PM
Not familiar with iPads, but I'm assuming it has a Wifi settings option which should be able to 'see' the signal output by the HH6 which you can then select and connect to using the Wireless Password/key.
17-08-2020 3:52 PM
17-08-2020 4:41 PM
Ipad:
How to manually join a Wi-Fi network
- Launch Settings from your Home screen.
- Tap Wi-Fi.
- Tap the network you'd like to join.
Enter the password if one is required.
17-08-2020 4:52 PM
17-08-2020 5:37 PM
17-08-2020 6:20 PM
17-08-2020 6:35 PM
17-08-2020 6:54 PM
