Switching from essentials fibre to unlimited?
HarmoniousLemon
Can this be arranged? I havnt been on this service for even a whole day yet, but I can already see Im going to struggle with this 40gb restriction!
I ve looked on the site to see if I could upgrade that part of our service but nothing new is highlighted at the moment, just the current package.
I know you ve probably been asked this question many times before! I just need a foot in the right direction to get the ball rolling Smiley thank you ^^
Hannah
Fixes: 62
Re: Switching from essentials fibre to unlimited?
You should have something like this when logged into the member centre - see pic
However if you do it that way you will lose any introductory offer - if that is the case I suggest phoning the Customer Options Team on the usual number
HarmoniousLemon
I did look there, unfortunately on the option to change product, the same product was the only option! You re probably right I should probably call them instead Smiley
Fixes: 62
Try this one then https://portal.plus.net/upgrade_process.html
Actually that  takes you to the same page which gives  this
I've made the change for you Smiley The reason it wasn't offering you the change was because the line check (run before any account change) was returning the result that FTTC is not available. Most likely explanation for this is that yours was the last order possible for the cabinet so it's now been removed from the list of those accepting orders.
Anyway, all should be sorted - hope that helps, and thanks very much for choosing us Smiley
HarmoniousLemon
Thank-you very much for changing it for us Smiley and such quick service too! You have a very happy customer ^^
Hannah
Quote from: Oldjim
see pic
@Oldjim - your user name is showing...
Fixes: 62
whoops - so it was - thanks for the heads up
