Switching from Virgin. Do I need to inform Virgin?
Jamesjmclaren
HI all,
I signed up to Plusnet today with an acitivation sometime in May before my Contract ends with Virgin. Do I need to inform Virgin or will Plusnet handle everything?
2 REPLIES 2
Fixes: 353
Re: Switching from Virgin. Do I need to inform Virgin?
@Jamesjmclaren You should not need to inform Virgin, if you used the OTS service, but keep you wits about you once you have moved - there is anecdotal evidence that sometimes Virgin forget you've moved, and try to continue billing.
PhilipHeyes
Seasoned Pro
Fixes: 5
Also be aware of VM's equipment returns policy, it is usual to be requested to return all equipment VM have supplied to operate their service ( VM Hub / VM Pods / VM TV units ).   Failure to return kit when requested attracts a fee.
