Swapping Gateways.
- Swapping Gateways.
Swapping Gateways.
25-11-2009 11:55 AM
I was always under the impression that the only way to change gateways was to reboot the router or for PN to force a swap from their end, which would in turn result in a router reboot. Yesterday I was doing some ping checks and noticed that I was on thn-ag1. I've just repeated the ping checks and have noticed that I'm now on thn-ag2; however my router stats don't show that a reboot has occurred. How is this done?
Message 1 of 7
(1,115 Views)
6 REPLIES 6
Re: Swapping Gateways.
25-11-2009 12:16 PM
If you have performed or incurred a PPP disconnection rather than a full router reboot.
Message 2 of 7
(461 Views)
25-11-2009 12:18 PM
OO ta Strat! I thought dropping the PPP would cause the router to initiate a resync but obviously not.
Message 3 of 7
(461 Views)
25-11-2009 2:33 PM
Doing a PPP drop is the best way as the exchange doesn't see any loss of sync. You can do that as often as you like without fear of the DLM giving you a higher target noise margin.
Message 4 of 7
(461 Views)
25-11-2009 3:55 PM
How do you just drop the PPP then without doing a manual resync or reboot?
Message 5 of 7
(461 Views)
25-11-2009 4:02 PM
Depends on your router, some have a way to do it, others you have to just reboot.
The plusnet supplied 585v7 has a button to disconnect/connect the internet which just drops the PPP sessions and re-establishes it.
Message 6 of 7
(461 Views)
25-11-2009 4:16 PM
Mine's a Voyager 2110. Is there a way to do it on that?
Message 7 of 7
(461 Views)
