Swap from ADSL MAX to wbc Re ticket 511978036
- Re: Swap from ADSL MAX to wbc Re ticket 511978036
27-02-2012 3:11 PM
^AW and ^JP were loking at it via twitter and I was asked to leave it 10 days.
28-02-2012 10:37 AM
28-02-2012 10:43 AM
28-02-2012 1:17 PM
Can I just confirm that you want 6dB SNR with interleaving on? Can I also ask are you using any extension cables/sockets? Do you have a test socke you can plug into?
Jojo
28-02-2012 1:25 PM
Plugged into master soicket filterd bt adsl faceplate no extension wiring
Also I did put it into the test socket with a brabd new adsl filter over the wekend no change as expected with no other wiring comming of the master it is a dedicated fax / adsl line almost a dedicated adsl line now only get a few faxes a month.
28-02-2012 8:04 PM
I have now requested your profile change to 6dB downstream SNR with interleaving. This normally takes effect within 24 hours. Let me know how that goes.
Jojo
29-02-2012 8:29 AM
before last week http://speedtest.net/result/1795640787.png
Results before wbc http://speedtest.net/result/1625108246.png ;
router now synced at 5122 yesterday 4349
i will do another reset after 10am if the snr is reported above 6db in my dsl diagnostics page on the 2700hg
Thanks for your help
29-02-2012 9:04 AM
I've just ran a test and you are currently at 6dB. The target is now 6dB as it should be too.
Jojo
29-02-2012 9:17 AM
02-03-2012 10:35 AM
dick:green Image tags added.
02-03-2012 2:56 PM
23-03-2012 8:55 AM
looks like exchange has swapped me to adsl2+ attn gone from 48.7 to 51.9 and loss of speed can i be put back on adsl2 please
23-03-2012 9:41 AM
Adam
23-03-2012 9:57 AM
23-03-2012 10:05 AM
