Suspect Router
valart
Suspect Router
Can someone tell me what are the signs that my router is giving me problems because I have had this router for fours years and at least about three or four times a week a loose connection but it does reconnects very quickly It is not too much of a problem but I thought it might be my Thomson router is showing wear I have the TG582n Technicolor just in case so I just wondered if I should try it.
cedlor
Re: Suspect Router
I know nothing but  will ask some preliminary questions
It has been doing this for 4 years?  if not when did it start?
What do the lights on the router do when it loses the connection.?
Please post the router stats.
What software does it have?
valart
Re: Suspect Router
It has been doing it for four years some weeks I have no disconnections at all,the internet light goes out on the router I'm not sure what you mean about software I am a elderly gent and i'm not use to this technology Uptime: 0 days, 19:45:20
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,159 / 11,228
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 169.00
Output Power (Up/Down) [dBm]: 12.0 / 0.0
Line Attenuation (Up/Down) [dB]: 12.5 / 29.5
SN Margin (Up/Down) [dB]: 7.0 / 3.5
Loss of Link (Remote): 0
FEC Errors (Up/Down): 4,294,967,244 / 0
CRC Errors (Up/Down): 4,294,967,244 / 24,221
HEC Errors (Up/Down): 0 / 4,011
Fixes: 6
Re: Suspect Router
Your stats don't show any significant errors but your downstream sync speed of 11,228Mbps is a touch slow for your attenuation of 29.5dB.
According to the following speed calculator your line should be capable of a max speed of 16,000Mbps.
http://www.kitz.co.uk/adsl/max_speed_calc.php
Not everyone will get the theoretical maximum speed, you need a perfect line for that.
It's always worth trying a different router so yes I would try the tg582n. You will probably need to manually enter your plusnet username and password before it will connect, so I suggest you enter those before connecting it to the phone line.
Setup guide for the TG582n:
http://www.plus.net/support/broadband/hardware/technicolor-582n-setup-guide.shtml
