Surely I should get more than 0.93 broadband speed?
- Surely I should get more than 0.93 broadband speed...
Re: Surely I should get more than 0.93 broadband speed?
13-11-2012 10:40 AM
Should give over 11Mbps.
13-11-2012 1:01 PM
14-11-2012 9:14 AM
Hi all,
This morning the bandwidth is looking better than ever, now at 10.1 down, but my current line speed is still showing 7.1Mbps & I have not been able to check my IP profile as it keeps getting stuck at the end of the upload test. It was always a bit unreliable but this morning I just cannot get past that point. Is it a case of waiting for everything to settle down, or does something need correcting again by one of the PN crew? Thank you once again
DSL Connection
Link Information
Uptime:
0 days, 6:27:13
DSL Type:
ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]:
1.144 / 10.307
Data Transferred (Sent/Received) [MB/GB]:
436,01 / 1,99
Output Power (Up/Down) [dBm]:
12,8 / 0,0
Line Attenuation (Up/Down) [dB]:
20,5 / 38,5
SN Margin (Up/Down) [dB]:
6,1 / 5,7
System Vendor ID (Local/Remote):
TMMB / ----
Chipset Vendor ID (Local/Remote):
BDCM / IFTN
Loss of Framing (Local/Remote):
9 / 0
Loss of Signal (Local/Remote):
1 / 0
Loss of Power (Local/Remote):
0 / 0
Loss of Link (Remote):
Error Seconds (Local/Remote):
2.734 / 0
FEC Errors (Up/Down):
0 / 0
CRC Errors (Up/Down):
13 / 8.730
HEC Errors (Up/Down):
4 / 22.237
14-11-2012 9:19 AM
14-11-2012 9:23 AM
14-11-2012 9:54 AM
Quote from: kmw350 This morning the bandwidth is looking better than ever, now at 10.1 down.
Op success. Around a tenfold increase in speed, just by 'fixing up' your internal wiring. If only all speed issues were this easy!
As jelv says - your Plusnet profile needs to update and should kick in within 12 hours, (or as soon as one of the lovely Digital Care team notices this thread has been updated.)
B.
14-11-2012 3:00 PM
so maybe Matt or Chris could assist again & correct this difference one last time?
Barry you are right, it is certainly a success, and I am very happy, & grateful for the experts watching over this forum
14-11-2012 9:40 PM
Max achievable speed is 21Mbps,
BT IP profile is 9.09
Plusnet current speed is 7.1
and my synch speed is 10+
so if you could correct it I'd be grateful, that will be me sorted then
14-11-2012 9:48 PM
14-11-2012 10:08 PM
15-11-2012 12:06 PM
An SNR reset may help but I'd prefer to see the connection more stable first as you've just moved over to 21CN.
15-11-2012 12:48 PM
thanks for checking this, BTspeedtest IP profile currently shows ~9 for me as compared to the PN current speed of 7.1.
But I'll be guided by you and the experts on this forum. I was following advice and reporting that I have seen no change since the move to ADSL2+ over 24hrs ago, so maybe that was pointless anyway.
But in any case, big improvements came from my re-wiring so I'm no longer stuck on 0.9Mbps
15-11-2012 12:55 PM
15-11-2012 1:00 PM
My Gateway is saying:
1.135 / 10.111
15-11-2012 1:17 PM
