Surely I should get more than 0.93 broadband speed?
kmw350
Is anyone else stuck on this constant low speed?
I pay for Extra & up to 20Mbps. Obviously I don't expect to get 20 in a rural area, but 0.8 to 1.0 ? Come on, surely I have a right to expect better than this.
Noisemargin is 11/16.4
attenuation is 21 up and 36 down.
Can anyone comment on why my speed is so low all the time?
Thanks Smiley
118 REPLIES 118
Oldjim
Resting Legend
Fixes: 63
Re: Surely I should get more than 0.93 broadband speed?
First something is badly wrong going by your attenuation figures
Can you post the information requested here and we may be able help http://community.plus.net/forum/index.php/topic,96155.0.html
kmw350
OldJim I'd really appreciate some expert advice, thank you for the swift response. I'm computer literate but not when it coes to these technical details.
Below are the details of my DSL Connection from the link given as I have no idea what I am looking at!
I don't want to moan as Plusnet have been really good, I've been with them 2yrs, and they have been helpful when needed, but I am just disappointed that I am always struggling for a decent speed.
It's ok till I want to download a large game file or watch a stream, then there is just no hope Smiley
I should add, I tested this from the main socket with no other equipment attached, as per the guidance. I did get a reading of 1.8 a couple of days ago, but only for a short time, then it was back at less than 1 again.
Any help you can give would be appreciated.
Link Information
Uptime: 1 day, 15:31:22
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 960 / 2.016
Data Transferred (Sent/Received) [MB/MB]: 30,08 / 152,98
Output Power (Up/Down) [dBm]: 12,4 / 19,3
Line Attenuation (Up/Down) [dB]: 21,0 / 36,0
SN Margin (Up/Down) [dB]: 11,0 / 16,5
Loss of Framing (Local/Remote): 61 / -
Loss of Signal (Local/Remote): 7 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 62.680 / -
FEC Errors (Up/Down): 2.010 / 44.496.346
CRC Errors (Up/Down): 1.212 / 170.371
HEC Errors (Up/Down): -.212 / 170.371 / 219.969
jelv
Fixes: 10
Could you run the BT speed test and give the current line speed as requested in the post Jim linked please.
Your noise margin is very high which is restricting your sync speed. Could you reboot your router ONCE during daylight hours and report the stats you've given again.
How many phone sockets do you have, is the router in the main socket and if there are others what is plugged in to them?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
kmw350
Hi jelv,
the speedtest shows the following:
Download 0.94
Upload 0.73
Ping latency 35.13
After a reset
Download 0.94
Upload 0.77
Ping latency 41.21
and also after reset:
Uptime: 0 days, 0:01:20
Bandwidth (Up/Down) [kbps/kbps]: 960 / 2.496
Data Transferred (Sent/Received) [kB/kB]: 12,37 / 15,63
Output Power (Up/Down) [dBm]: 12,6 / 19,8
SN Margin (Up/Down) [dB]: 11,0 / 15,9
Loss of Framing (Local/Remote): 18 / -
Loss of Signal (Local/Remote): 2 / -
Error Seconds (Local/Remote): 69 / -
FEC Errors (Up/Down): 1 / 25.775
CRC Errors (Up/Down): 0 / 194
HEC Errors (Up/Down): - / 194 / 391
I have 5 sockets:
the main one in my front window, & three further downstairs sockets; then a fifth in an upstairs bedroom.
I only use two of the sockets, one for my router which also has a phone plugged into the filter; and one for the sky tv.
None of the other sockets are used.
I tested from the router's usual socket without the phone attached.
I will do the same from the main socket and report those figures also.
Keith
Oldjim
Resting Legend
Fixes: 63
Is the main socket a proper master socket with a removable lower section.
If so you will need to check using the test socket behind it
The video in my original link explains why
jelv
Fixes: 10
Quote from: kmw350
Are you using an ADSL filter in the socket for the Sky TV?
kmw350
JIM, JELV,
I don't know whether to laugh or cry. For two years I have put up with less than 1M.
Following your advice, the main socket is giving me.......
over 5 !!!
I cannot believe it.
First, I feel like a right idiot.
Second, I cannot thank you enough.
Third, I presume I will have to take a serious look at my internal phone lines now to get the same figure at my pc in the back room.
That will be a pain, but a least I can see that it will be worth it Smiley
I must say, I am not normally the sort of person to skip over reading guides, and honestly, I had read through it but I had missed the video and in particular the point of testing from the absolute(internal) main socket, so my previous tests from the main socket were only from the outside of the box.
I have some work to do now, thank you so much for your help, is there anything really obvious that you would look at first, before I look at the whole route of my wires?
EDIT: jelv, only just saw your quesiton re sky, no there is no filter on the sky socket. Is it too much to hope that it will be enough to solve this?
Thank you again,
Keith
jelv
Fixes: 10
That will likely be the cause of all your grief.
To confirm the internal wiring is OK unplug the Sky and check what the stats are like using the front of the main socket.
Edit: See the Plusnet help page: http://www.plus.net/support/broadband/microfilters-how-and-why.shtml#howMany
kmw350
unfortunately, it was not that simple. I plugged in a new microfilter in the sky socket (also tried a second new one), and tested from the outside of the socket, and I am back at 0.94 again Sad
So I need to check the connections in the sockets and determine what is draining my signal.
I will get to work on it.
Thank you again, at least I know there is a very good speed reaching the house!
jelv
Fixes: 10
All of the extensions should be connected to the removable part of the master socket (it would be good to check that when the front plate is removed all the other sockets are dead).
You can get a replacement for the removable part of the master socket with a built in filter, the extensions are then connected to the filtered side. This might be an option for you: http://www.adslnation.com/products/xte2005.php. You don't then need any filters elsewhere in the house.
You can get similar units from other places.
kmw350
jelv,
thank you I will look at fitting a new master socket.
BUT, I knew it was too good to be true. I went back to the test socket to make sure it was still at 5, and it is now showing 0.94, just like the rest of the house. I have not touched the master socket, other than to remove the lower cover.
I even started doubting the fact that I ever saw the 5.7 in the first place, (though I know I did!).  Angry
Does it suddenly drop at the exchange for some reason? What the %$£" is going on?
I was going to try and be methodical, and was happy that the problem was inside the house, but it's going to be impossible if the main socket is going to vary that much, there is obviously a similar problem outside as well.
Is it even worth trying if this is the case? Sad
jelv
Fixes: 10
You need to check not only the sync speed but the noise margin.
Have you installed RouterStats?
I'd suggest putting in to the test socket and running it like that for a couple of days to check if it's stable and watch the noise margin graph.
kmw350
ok thanks,
currently the SN Margin shows (Up/Down) [dB]: 11,0 / 16,3
Could you tell me what i should be reading? Is this good or bad?
I'm afraid I am not too good on understanding most of this information.
For instance, when I plug into the test socket and check the Gateway stats my bandwidth is shown as 960/6.464.
As soon as I plug it in on the outside of the socket I have a drop to 960/3.8.
If I check the BT test result, the speed shows as 0.94 downloading.
So is this pointing to a faulty main socket maybe?
I will try routerstats if I can get it running thanks.
Oldjim
Resting Legend
Fixes: 63
I am a bit confused
In your post
were you referring to a speed test or router stats. If a speed test then it would still be rotten until the Plusnet profile increases
If as you say in your last post the stats are consistently much higher in the test socket then you have an internal wiring problem
