Support ticket 63857505 - Slow speed.. IP Profile stuck at 2 Mbps
- Support ticket 63857505 - Slow speed.. IP Profile ...
29-12-2012 7:32 PM
I had this exact same problem last year, please see my topic here for all the info: http://community.plus.net/forum/index.php/topic,98812.0/topicseen.html
Router: plusnet supplied Thompson TG585 v7
BT socket: NTE2000 faceplate fitted, ie I don't use any external filters.
Computers: my PC is connected via ethernet cable, we also have laptops but none are connected via wireless during any tests I've ran.
The problem started this month with speed limited to under 2mb, IP Profile once again seems to be stuck at 2 Mbps and hence I'm only getting around 1.8mb download speed! Normally I get 6.5-7mb in download speed.
Support ticket: 63857505
BT Speedtest results attached.
Router stats attached (unfortunately the router decided to randomly restart itself whilst I was in the menu so hence short connection time)
Please look into it for me? thanks
Message 1 of 2
(698 Views)
1 REPLY 1
Re: Support ticket 63857505 - Slow speed.. IP Profile stuck at 2 Mbps
02-01-2013 10:46 AM
Having checked I can't see any issue with the profile that's currently set for your line.
I can't see any other obvious causes I'm afraid but I can see that you've raised a fault ticket, you should have a reply ASAP assuming that this is still an issue for you.
Adam
Adam
Message 2 of 2
(334 Views)
