Support system confusing, difficult to use and designed to prevent contact?
- Re: Support system confusing, difficult to use and...
23-03-2012 10:17 AM
In brief, just signed up with Plusnet. For the first week or so, all good, connection reliable and speeds reasonable (for my area).
Now my "broadband" connection is unusable (basically slower than the dial up I had 15 years ago - pages taking 1 or 2 minutes to load or failing completely). No changes have been made to my home setup.
Today I tried to report the problem via the Plusnet website (from work, because my home connection is unusable). I simply want to raise a support ticket for my problem, but I was unable to find a page where I can do this. Following the support links for broadband speed problems forced me into an extended troubleshooting questionnaire. Ultimately I was asked the following question:
"Our records show that your connection has dropped at least twice a day recently. When the connection drops, what happens? - A: the router broadband light flashes or B: the router broadband light does not flash".
I was not aware that my connection has dropped at any time, so I have no idea what the router lights are doing, and therefore I cannot answer this question correctly and proceed.
How can I report a problem?
Message 1 of 5
(1,031 Views)
4 REPLIES 4
Re: Support system confusing, difficult to use and designed to prevent contact?
23-03-2012 10:29 AM
answer ether of them
then in the comments box write the same as you have on this thread to explain
i do agree the questions should have a none of the above answer on them as well
Message 2 of 5
(419 Views)
23-03-2012 11:02 AM
Thanks for the feedback chaps,
@kcrussell I can see that ticket 53585717 is now open with us, our tests will have picked up that there are a number of disconnections seen against your line which is why it prompted that question.
Our faults team will be picking up on your ticket ASAP before getting back to you.
Message 3 of 5
(419 Views)
23-03-2012 1:35 PM
Thank you.
I originally posted this in feedback because the thing I found frustrating was the process of trying to raise a ticket. My broadband service is not working correctly, but I understand this may take time to investigate and resolve. Not having a straightforward process to report the issue, however, is really annoying!
Message 4 of 5
(419 Views)
23-03-2012 3:48 PM
Hi kcrussell,
It looks like you need to go back and finish answering the questions before it gets picked up.
Jojo
Jojo
Message 5 of 5
(419 Views)
