Support Staff - request for speed reset and ticket update
- Support Staff - request for speed reset and ticket...
14-10-2010 6:44 PM
This is all detailed in ticket #35891159
I've checked my connection today and it's been fine since yesterday morning: syncing at 8128/448. The download speed remains ~300kbps however.
Can you please do what's necessary your end, as I have a visit scheduled from BT on Saturday morning. I need to know if they still need to attend.
As it seems the line is now OK, I'm keen to avoid a massive bill from Openreach if they actually come out unnecessarily.
It would also be nice to have an update from your end
Re: Support Staff - request for speed reset and ticket update
14-10-2010 9:48 PM
Your BT & PN profiles are now back up to 7150, go into your router and disconnect then reconnect and you should see the difference.
Jojo
14-10-2010 10:55 PM
Thanks for your help, now up to 6129 for the first time in over a week
I've done a disconnect/connect through the router interface, which has kept the DSL line up throughout.
Is it safe to do a power off reset? After gaining this speed back I don't want to accidentally signal to the DLM gubbins at the other end that there may be a line fault
14-10-2010 10:58 PM
If you need to turn the power off just make sure you disconnect from the router interface before you unplug it.
Jojo
14-10-2010 11:05 PM
1: Router interface - Disconnect (this drops the PPP link)
2: Switch off router, (or simply unplug the lead from the socket?)
If it's done in this order, is it a preferred and more graceful way of 'switching off' without making the exchange end think that there's a line fault?
A bit like shutting down Windows first then unplugging the PC
15-10-2010 10:28 AM
Yeah, it just lets the system know it was an intended disconnection.
Jojo
15-10-2010 12:46 PM
As the line appears to be working now, can you confirm that you are happy with things at your end? If so, please cancel the visit by BT Openreach scheduled for tomorrow morning, so that this slot can be released for another user (and avoid the risk of a big bill for me!).
(I've put this on the ticket #35891159 as well, although that doesn't seemed to be responded to now).
Thx
15-10-2010 1:17 PM
Ok that's been cancelled now and your ticket will be updated then send back to you where it'll stay open for 14 days in case it re-occurs.
Jojo
18-10-2010 1:30 AM
Incidentally, after I went over the 15GB monthly allowance recently, how soon was the cap removed? (I phoned and had an extra gig added for an extra quid in advance of the billing date, which was just a few days away).
thx
18-10-2010 9:23 AM
Hopefully that's done the trick. The cap should have been lifted as soon as the agent added the extra usage.
Jojo
