Super Slow Upload Speed....Now Dead no PPPoa
popeyeuk
Hi All
My router connects and syncs...all fine
Modem Status   connected
DownStream Connection Speed 8128 kbps
UpStream Connection Speed 448 kbps
But browsing the net is super slow and If I do a spped test using the tool on Plusnet site...I get this:-
48 REPLIES 48
Phantom_Flan_Fl
Re: Super Slow....
If your problems have only arisen today, it could be caused by the underlying issues Plusnet currently have with their Broadband.
You seem to be one of the lucky ones who can actually browse, but for many of us, although we show as connected, we can't do anything else.
Steve
Seasoned Pro
Re: Super Slow....
Looks to me like your upload Is a bit Knackered.
If life gives you lemons, make lemonade.
jojopillo
Re: Super Slow....
Hi popeyeuk,
I have just ran a few line tests and don't see any obvious issues, your sync speed is good, the VP is ok and no recent issues at the exchange. So the first thing I would do would be to visit our troubleshooting page where, if the checks are unsuccessful it will enable you to raise a fault.
Jojo Smiley
popeyeuk
Re: Super Slow....
Thanks for the replies all...
I did have problems when first connecting to Plusnet (streaming music connect would drop out)..  After second Thomson router with same issues I bought a brand
new netgear which syncs and connects at full speed...
The browsing thing started about a week ago and has got worse  and it seems to be connected with my upload speed..  I can download files
at 7 to 800k a second but browsing is terrible..  Also interesting if I ping -t  Plusnet DNS servers 212.159.6.10 or  212.159.6.9 I do a regular
"Request Timed Out" entry.....
More to follow I'm sure.....
Oh yeah just for reference here's the router stats
ADSL Link  Downstream  Upstream
Connection Speed 8128 kbps 448 kbps
Line Attenuation 19.0 db 10.5 db
Noise Margin 8.0 db 25.0 db
popeyeuk
Re: Super Slow....
Wow how many hops to a plusnet server....  Look at hop 5 failed...!!!
TraceRoute to 212.159.6.9 [cdns01.plus.net]
Hop (ms) (ms) (ms) IP Address Host name
1 21 17 6 72.249.0.65 -
2 10 6 47 8.9.232.73 xe-5-3-0.edge3.dallas1.level3.net
3 19 30 23 4.69.145.51 ae-62-60.ebr2.dallas1.level3.net
4 20 18 50 4.69.137.122 ae-3-3.ebr2.newyork1.level3.net
5 45 Timed out Timed out 4.69.148.46 ae-92-92.csw4.newyork1.level3.net
6 43 52 64 4.69.148.46 ae-92-92.csw4.newyork1.level3.net
7 112 171 92 4.69.134.77 ae-91-91.ebr1.newyork1.level3.net
8 112 122 115 4.69.139.106 ae-2-52.edge4.london1.level3.net
9 153 Timed out 129 195.50.122.130 -
10 138 135 122 212.159.2.252 vl63.pcl-lb01.plus.net
11 124 124 128 212.159.2.252 vl63.pcl-lb01.plus.net
12 133 122 158 212.159.6.9 cdns01.plus.net
Trace complete
And to the other one...
TraceRoute to 212.159.6.10 [cdns02.plus.net]
1 23 16 24 72.249.0.65 -
2 66 46 24 8.9.232.73 xe-5-3-0.edge3.dallas1.level3.net
3 52 52 44 4.69.145.51 ae-62-60.ebr2.dallas1.level3.net
4 87 80 50 4.69.137.122 ae-3-3.ebr2.newyork1.level3.net
5 Timed out 49 Timed out 4.69.137.122 ae-3-3.ebr2.newyork1.level3.net
6 Timed out 89 72 4.69.134.77 ae-91-91.ebr1.newyork1.level3.net
7 74 136 79 4.69.134.77 ae-91-91.ebr1.newyork1.level3.net
8 115 116 113 4.69.139.106 ae-2-52.edge4.london1.level3.net
9 112 119 148 4.69.139.106 ae-2-52.edge4.london1.level3.net
10 118 116 114 212.159.2.252 vl63.pcl-lb01.plus.net
11 137 125 133 212.159.6.10 cdns02.plus.net
Trace complete
jojopillo
Re: Super Slow....
Hi popeyeuk,
Is this trace from a plusnet connection, because it doesn't look like to me. You were tracing to a plusnet caching DNS server which is for lookups for plusnet connections. The results you have posted don't really tell us anything.
From a plusnet connection it should look something like this.
1    1 ms    1 ms    1 ms  home.gateway [192.168.1.254]
  2    18 ms    18 ms    19 ms  lo0-central1.pcl-ag05.plus.net [195.166.130.34]
  3    18 ms    18 ms    18 ms  gi7-8-512.pcl-gw02.plus.net [84.93.254.51]
  4    21 ms    18 ms    18 ms  vl63.pcl-lb01.plus.net [212.159.2.252]
  5    18 ms    17 ms    19 ms  cdns02.plus.net [212.159.6.10]
Jojo Smiley
popeyeuk
Re: Super Slow....
Yo Jojo you are right my error... these look better... Wink
http://212.159.6.9/
1 192.168.0.1 unknown 0ms
2 195.166.128.236 lo0-central2.pcl-ag02.plus.net 31ms
3 84.92.6.40 gi1-24-221.pcl-gw01.plus.net 31ms
4 212.159.2.252 vl63.pcl-lb01.plus.net 31ms
5 212.159.6.9 cdns01.plus.net 31ms
and
http://212.159.6.10/
2 195.166.128.236 lo0-central2.pcl-ag02.plus.net 46ms
3 84.92.6.40 gi1-24-221.pcl-gw01.plus.net 46ms
4 212.159.2.252 vl63.pcl-lb01.plus.net 62ms
5 212.159.6.10 cdns02.plus.net 62ms
jojopillo
Re: Super Slow....
Ah, ok. what was it you were doing?
Jojo Smiley
popeyeuk
Re: Super Slow....
Hi Jojo
The first time I ran traceroute from a website so it showed the wrong route...doh  Second time I dowloaded some software
so it was from here... Wink
My problem is deffo packet loss..  If I ping-t  any IP I get around 5% loss ... see below..
Ping statistics for 212.159.8.91:
    Packets: Sent = 103, Received = 97, Lost = 6 (5% loss),
Approximate round trip times in milli-seconds:
    Minimum = 46ms, Maximum = 254ms, Average = 52ms
I will do all the diagnostic thing again.. bit of a drag as I did it all about 3-4 weeks ago for another fault.. Undecided
jojopillo
Re: Super Slow....
Hi Popeye,
I know what you mean about it being a drag but look, I'll see what I can come up with when I get in in the morning.
Jojo Smiley
Steve
Seasoned Pro
Re: Super Slow....
Is It not just your MTU Setting's needed set correct?  http://www.kitz.co.uk/adsl/MTU2.htm
jojopillo
Re: Super Slow....
@steve M,
If it's Vista or windows 7 then probably not.
Jojo Smiley
popeyeuk
Re: Super Slow....
Quote from: Joanne
Hi Popeye,
Jojo Smiley
Jojo you are a star and definitely need a pay rise for your dedication...  Do you ever clock off?
I will do the diag stuff again if needs be..  Funny I can download large files but posting to this forum
takes up to 3 mins from hitting the post button..
@Steve M    I have 3 PC's which are connected to net via a router and the problem is on all of them
2 x XP and 1xVista... I also have 4 routers..  2 x Thomson 1 x Dlink and the new Netgear..
Hey but thanks for the input keep em coming...  Wink
popeyeuk
Re: Super Slow....
Hello guy's an update...
Done further tests this time from test socket...
Speedtester runs but only download test  around 725k/b sec so all good....  I can stream Iplayer HD no problem but browsing sites
is like pulling teeth..
Upload test won't run throws error reading upload file....  This happens with the tree testers I tried.. Undecided
Ping -t  test to google.co.uk and plusnet.com shows between 5% and 9% packet loss..
Anyway at least I can log a support ticket now..
Cheers
Steve
