Sunday Speed Problems - ADSL-v-FFTC
- Sunday Speed Problems - ADSL-v-FFTC
02-02-2014 9:27 PM
I always seem to have a slow down in speed on a Sunday.
I'm on ADSL.
I've run the BT wholesale speed test, which says:
Download speedachieved during the test was - 0.2 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 5.7 Mbps
When I went through the the later tests (when you need to put in BTs DSL username in your router), it says:
Download speedachieved during the test was - 5.05 Mbps
And at the bottom, it says:
"Your service was found to be performing poorly.
Please raise a fault with your service provider, stating that the BT Performance Tester tool indicates poor service throughput performance after the third test."
I've been thinking of upgrading to PlusNet's FFTC service.
Will I see the same problems using FFTC, or will my problems be related to ADSL only? Althought I've been with PlusNet for years, I don't want to stick with them if I've going to continue with a poor connection.
Thanks.
I'm on ADSL.
Thanks.
Message 1 of 8
(1,340 Views)
7 REPLIES 7
Re: Sunday Speed Problems - ADSL-v-FFTC
03-02-2014 2:21 PM
Hi amaye,
Are you aware of anything specific that happens in the area on a Sunday that might cause the low speeds?
What sort of time on a Sunday are we talking?
Message 2 of 8
(786 Views)
03-02-2014 10:43 PM
Thanks for the reply.
Noticed it on Sunday from late afternoon through into the evening.
Noticed it before several times.
I'm not sure what you mean about other things going on.
Message 3 of 8
(786 Views)
04-02-2014 10:12 AM
Which exchange are you on?
Message 4 of 8
(786 Views)
04-02-2014 10:17 AM
Is the issue still ongoing?
I was asking whether there were any works going on in the area, such as, Water/Electric or Gas works?
Message 5 of 8
(786 Views)
04-02-2014 11:05 AM
I just did a speed test now and got 4.47Mbps.
My perception is that it's a regular occurrence on Sunday's, but I can't say I've kept records.
My exchange is Sale (MRSAL).
I'm thinking of moving to FFTC, but I don't want to stick with PlusNet if this kind of service continues. I'm most likely to use iplayer or whatever on a weekend. It's unusable on Sundays.
Message 6 of 8
(786 Views)
04-02-2014 11:08 AM
Right, okay, thanks for the information.
It might be worth completing the Broadband Fault Checker at http://faults.plus.net so our Faults Team can investigate further.
Message 7 of 8
(786 Views)
04-02-2014 3:21 PM
You may see the same slow downs with FTTC on Sundays /Mondays I know that i do, it's not REIN or crosstalk that only happens during those slow periods (usually plusnets peak time 7.30pm onwards) but some times on a Sunday throughput can drop off earlier on late afternoon , Which could suggest that something is acting as a bottleneck for the volume of traffic passing through it during those times , be it faulty kit on the network or insufficient capacity somewhere ,
Message 8 of 8
(786 Views)
