Sugestion: Simply change to invoicing on portal
- Sugestion: Simply change to invoicing on portal
23-10-2007 4:49 PM
List invoices in reverse date
This way the one I need to access with be at the top of the list, and when you manage several accounts scrolling down becomes a pain.
Roll on the day when pdf invoices are send by email - but that's a whole different subject! Until then how about the above suggestion PlusNet?
Re: Sugestion: Simply change to invoicing on portal
23-10-2007 4:59 PM
If it hasn't been done already, then I would strongly advise raising this in PUGIT.
http://usergroup.plus.net/pugit
I suspect it may have already been raised though.
23-10-2007 5:03 PM
BTW: There's no www in it
23-10-2007 10:47 PM
23-10-2007 11:24 PM
PUGIT Issue 27 PDF Invoice Sent by Email
Item link here.
Comment topic link here.
This item has 38 votes; PlusNet commented on 10 Oct 07 "it's a definite in terms of wanting to do it - I see the vote count is growing. More votes will help priority!" So get voting!
Edit: to clarify that the first line refers to PDF Invoices and to add:
As far as the suggested stop-gap solution is concerned do others share the original poster's "pain"?
23-10-2007 11:29 PM
We are currently going through an exercise of prioritising the many hundreds of feature requests we have in a way we never have before. This should stop the 'big ticket' items from continually diverting us from these sorts of simple tasks longer term. We still need more help in terms of voting to define prioritisation though.
Expect to see more about this process in the coming months...
Ian
23-10-2007 11:44 PM
Quote from: Ian Why is "List invoices in reverse date" the same as PDF Invoices by email Spraxy?
Quote from: Username Roll on the day when pdf invoices are send by email - but that's a whole different subject! Until then how about the above suggestion PlusNet?
The second quote is from the original post; PDF invoices seems clearly to be what the OP would really like. So raising another one for the stop-gap solution did not seem constructive. Perhaps I could have made my post clearer and I will edit it to do so.
24-10-2007 12:10 AM
24-10-2007 12:45 AM
24-10-2007 5:12 AM
24-10-2007 8:19 AM
http://portal.plus.net/central/forums/viewtopic.php?t=25821&highlight=
....and PDF issue.
http://portal.plus.net/central/forums/viewtopic.php?t=10949&highlight=pdf+invoice
24-10-2007 4:16 PM
Yes PDF invoices would be great, but I can imagine the extra work load required to make this happen, as in interim step how about Reverse Order - this I would have thought would require a very minor change...
Quote from: spraxyt PDF invoices seems clearly to be what the OP would really like. So raising another one for the stop-gap solution did not seem constructive.
24-10-2007 6:37 PM
Discussed in this tread from late July in the old MN forum :- http://portal.metronet.co.uk/central/forums/viewtopic.php?t=1025
so it would seem that some work was being done on the subject.
Raised a ticket as requested but I had no reply from PN/MN why it had happened. Got another PDF proforma in August but not in Sept. I still have the attachments if anyone's interested.
I generate large numbers of PDF's and these are quite big for what they are - 1mb plus. I wouldn't expect this type of thing to come out at more than about 50k.
If PN were looking at sending out pdf invoices to everyone (@1mb a time!) that's quite a bit of bandwidth . . .
Looking into the details, both pdfs were authored by Phil Richardson on 07/03/07 using Illustrator CS2.
Alastair
24-10-2007 6:55 PM
Quote from: Original
I've just gone to my latest invoice and viewed the printable version, then printed it using PDFCreator (free software from SourceForge) to turn the invoice in to a PDF. It was 8K
24-10-2007 7:19 PM
I though maybe the PN logo was a bitmap or tiff image which would push the size up, but the logo is a vector.
Re-saving it as a vector file pushes the size up to 760k. Very strange - don't see anything on it that would make it so big.
I can get it down to 130k with some fiddling in Indesign, but it still shouildn't be that big.
Interestingly, there's a box on the bottom that states:-
Please return this invoice when sending
your payment, and enter on the reverse
of your cheque your username and
postcode
Just weird
A
