Suddenly getting relay.pcl-ipout01.plus.net errors!
- Suddenly getting relay.pcl-ipout01.plus.net errors...
21-01-2009 5:08 PM
Your message did not reach some or all of the intended recipients.
Subject: RE: response to email
Sent: 21/01/2009 16:34
The following recipient(s) could not be reached:
name@domain.co.uk on 21/01/2009 16:46
The e-mail system was unable to deliver the message, but did not report a specific reason. Check the address and try again. If it still fails, contact your system administrator.
< relay.pcl-ipout01.plus.net #5.0.0 smtp; 5.1.0 - Unknown address error 550-'Verification failed for <prvs=nnnn.nnnnnnn=nnnnnnnn@anotherdomain.org.uk>\nNo such user at this domain \nUnable to verify sender' (delivery attempts: 0)>
Re: Suddenly getting relay.pcl-ipout01.plus.net errors!
21-01-2009 5:13 PM
21-01-2009 5:15 PM
Quote Is it likely to cause problems?
No.
21-01-2009 5:19 PM
Bob's looking into this now for you.
21-01-2009 5:25 PM
Also, seems to be both relay.pcl-ipout01.plus.net and relay.ptn-ipout02.plus.net
21-01-2009 5:26 PM
21-01-2009 5:37 PM
21-01-2009 5:50 PM
21-01-2009 10:39 PM
Any ideas what's going on?
Cheers,
Duncan
21-01-2009 10:43 PM
Quote been having it since some time this morning.
Any chance you can PM me one of the emails this happened to from before 4.30ish please?
21-01-2009 11:14 PM
21-01-2009 11:31 PM
I also am having the same issue. I have two PC's one with Outlook 2007 as the e-mail client is working fine for sending out e-mails.
The other using Thunderbird ( latest version) is getting the same errors.
"5.1.0 - Unknown address error 550-'Verification failed for ..........
Reporting-MTA: dns; relay.ptn-ipout01.plus.net"
Both PC's and e-mail clients are using relay.plus.net as the outgoing SMTP server.
I have NOT made any configuration changes.
I am unclear why this is happening and to honest not sure what light this throws on the issue?
But when there is a difference like this I am sure it is flagging something, perhapps someone may have an idea?
I only noticed this around17:15 when I noticed about the IronPort change and decided to test!
While I am all for changes that reduce spam, it does appear that this change may be causing some issues? Or is it co-incidence?
Can we please have some higher visibility on this, I am happy to raise a ticket if that will help, but from an earlier posting it appears that CSC may be getting some calls about this.
I hope this helps and in anticipation of some updates soon
22-01-2009 9:10 AM
Has anyone found a cause or even a resolution for this?
22-01-2009 9:53 AM
22-01-2009 10:05 AM
