Suddenly broadband very slow
IanSn
Can anyone check to see if my connection has issues?
Waiting ages for pages to load, etc.
Checked BT wholesale - 6.21 Mbps
No changes to anything, usually get around 16 Mbps
37 REPLIES 37
Legend
Fixes: 255
Re: Suddenly broadband very slow
@IanSn Is this an ADSL or FTTC connection? Which modem/router are you using?
IanSn
Sorry, its ADSL. Its a fairly new PlusNet router. The numbers are all over the place. I've now had a 16 and an 8 Mbps.
Legend
Fixes: 255
OK Ian. From what I have read, the Help Team are a little busy, so I am going to post my 'Help sheet' and hope I can spot something to help you before I finish on here for the rest of the week.
For Community members to be able to help, information from these two sites, as screenshots:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub would be a good starting point.
For the Hub One -
For the Hub Two -
If phone test is OK then take the front off your telephone master socket, you may need to remove two screws. In behind you will find the test socket. Plug a filter in here and connect that to your hub. If it’s still dropping out then report a fault at https://faults.plus.net.
IanSn
Thanks John
Sorry for delay - Oddly the submit button on the BT Broadband link doesn't submit. Tried this a few times.
Performance Test attached. This time 15 Mbps, but as I said, this is varying wildly.
Quite Line is very quiet indeed!
Dont have a master socket here, nothing to unscrew.
Sorry, I don't know what you mean by 'broadband connection status' or Hub 1 / 2. Is that the PlusNet home screen you are refering to?
(SaferNetworking update is currently downloading at Kb/s. But that might just be their line.)
  ian
Legend
Fixes: 255
Thanks for the BT Performance Report, Ian. Unfortunately, as I have noticed on one or two others recently, it is reporting wildly inaccurate figures, so is not a great help, but from the bit of it I can fairly safely rely on - the reported IP profile - you must be on a reasonably short line from the exchange, so you get a good connection speed.
You must have a master socket, otherwise you wouldn't have a phone or BB connection 😉, but I don't think that last bit would be any great help anyway.
Which actual modem/router do you have, and then I'll post a picture showing you how to access the required information?
IanSn
Yes, very close to exchange, normally its very good.
Its a small PlusNet SagemCom, if that means anything? Nine lights across the front.
The master socket is just a flat 'light-switch' type panel with one slot for the cable/filter to plug in. Obvs pretty old.
The speeds are going from good to extremely slow and then back again. Its been doing it for a week or so. Lots of spinning wheels.
I've been trying to figure out why the fluctuations. Thought there might be a line issue.
I could contact the phone supplier maybe? Or give it a while longer and see if it rectifies?
  ian
Legend
Fixes: 255
Ah, so a very old 2704N then (identity will be on a label, probably on the bottom), and unfortunately not one I have had experience with or got any data for.
Is that 'master socket' at the point your phone line enters your hose or  on a cable running from that point - if not, it is conceivable that it isn't the master socket ?
If the phone is passing the Quiet Line Test, the issue must be on the broadband side of the circuit, so I would report a BROADBAND issue via this link: https://www.plus.net/help/report-a-problem/broadband/
IanSn
Found it. 2704N. Old, eh?  Hmm, I got this one fairly recently from PlusNet when my old one packed up. Paid for it, too.
Its a flat in a block on the first floor. Its the point where the cable enters the flat, near the front-door. Prior to that, I don't know. I've looked at the help pages which show various types of master socket, this one is none of them! Its not a box.
Ok, I'll give it a few days and then try the link you suggest here.
Many thanks for your help, appreciated.
  ian
Legend
Fixes: 255
If it is a 2704N, Ian, it IS old - PN haven't been supplying those for, at a guess three years - maybe more. Sounds like you have a non-standard installation then is this a flat conversion, or purpose built?
The problem isn't going to go away on its own - - I suggest you report it immediately.
Mustrum
Fixes: 77
@jab1  PN have issued them to ADSL customers until quite recently.
IanSn
Its a block of purpose-built flats. 1980s I think. Its rented. Owner has never updated line/box.
Very slow at the moment, took a while to get this page to load. Yes, I'd better sort it out.
Should I get a new router? Maybe its on the way out already.
IanSn
I know it!
Legend
Fixes: 255
@Mustrum Thanks - didn't know that - are they still in the 'faqs' as current issue?
Mustrum
Fixes: 77
@jab1  they are otherwise known as the Hub zero and still mentioned in the Help section, as is the old Technicolour 582n.
