Sudden speed drop
- Sudden speed drop
- « Previous
- 1
- 2
- Next »
Re: Sudden speed drop
08-01-2015 9:36 PM
Quote from: plusnettony Hi,
Can you confirm the download speeds? Can you please also run the test, when it's slow, through the BT speedtest site at http://www.speedtest.btwholesale.com/ . Ensure you do this via a ethernet connection, not wireless.
Thanks,
Tony
15.13mbps - All seems fine now thanks.
19-01-2015 4:36 AM
Please could you investigate. And reset my line.
The only outages I've experience are when. I have renewed my connection through my router whilst cofigering it. Is there a problem with my line?
Please can you reply today.
19-01-2015 10:44 AM
My normal Speed should be 14.5mbps.
Have BT DLM my line yet again???? Please sort this out as it's becoming rather annoying.
dick:quote
19-01-2015 1:16 PM
Quote from: tooslow BT Wholesale Speed Test: 8.62mbps
[Moderator's note by Dick (Strat): Full quote of preceding post removed, as per Forum Rule]
Is there anyone looking into this for me? Thanks.
19-01-2015 1:31 PM
The last reset we did worked briefly, but continually resetting the line isn't going to resolve whatever is causing the connection to drop so much.
I'd advise getting this looked at as a fault by going through https://faults.plus.net
19-01-2015 2:05 PM
Quote from: Chris DLM will have intervened on your line as it's disconnecting a lot.
Mate.
Your graph is showing the LAST issue of DLM. Which I explained at the time was me configuring new routers! Plusnet have reset my internet on the 7/1/15 - So why show disconnections prior to that as the cause of the DLM now? Since the 7/1/15 I have disconnected my router a dozen times or so but through the router first (as you advised), and these coincide with the graph you have shown me.
You told me last time that to AVOID DLM I should go into my router and and disconnect through the router software first!
This is what I have been doing and it is very clear that the so called outages are due to ME ENDING SESSIONS AND RENEWING THEM! though my router and NOT a line fault.
Jeez, cannot i not even breath on my router without DLM kicking in?????? This is ridiculous. Can you not disable DLM on my account - I fear buying a new router now, as yet again, you guys will see it as the set-up as a disconnection!
PLEASE RESET MY INTERNET. SO THAT NORMAL SPEED CAN RESUME AGAIN.
19-01-2015 2:09 PM
I can see that several of them show as 'User Request' which is what we'd expect to see, but there are many more showing a lost session.
I'll reset your line one more time, but if the disconnections continue I'd strongly advise this being looked at as a fault.
19-01-2015 2:31 PM
Quote from: Chris All of the disconnections over the weekend were configuring the router? 23 sessions since Friday seems excessive for that.
Thank you.
1.Is there a way I can see that graph for myself to check periodically to see If I am experiencing loss sessions?
2.Do you think any settings on my router that might be cause of lost sessions?
3.I have noticed that I assigned a different IP address on each session renewal - is this normal?
4.Is there a way to disable DLM you end? Surely, if there is a fault I will notice and report it.
5. Please put up a Sticky on here explaining how DLM works and what causes it - it would be helpful.
19-01-2015 4:23 PM
No, only PlusNet can access that report directly unfortunately.
Don't know what router you have but if it's anything like the PN Thompson router it's hard to do anything 'silly' with the settings unless you've got out of your depth using telnet commands.
Yes, unless you have asked for (and paid for) a static address.
Very few lines are perfect - DLM is there to automatically manage each one individually for the best combination of speed and stability.
DLM is a feature of your broadband connection rather than a problem (at least, it's not supposed to be! :D) - THIS article explains how it works, although it's a bit technical.
19-01-2015 6:23 PM
Quote from: JayG 1.Is there a way I can see that graph for myself to check periodically to see If I am experiencing loss sessions?
Thanks - But can you tell me, does DLM work in reverse and correct the speed if no outages/faults are detected for a few days???
I've also read that is you keep the router off for more that 30 minutes then DLM does not register it? Is this correct?
PS: I've just changed some settings on my router so please make sure they don't contribute to another speed DLM speed restriction.
- « Previous
- 1
- 2
- Next »
