Sudden reduction in speed since Sunday Afternoon
snortotter
Hello,
I normally get download speeds >10Mb/s, however from Sunday I can only get 3.5Mb/s, this speed confirmed from the wholesale broadband speed test and plusnet portal has the following:
Phone exchange: EASTON
Estimated line speed:10Mb (This may vary between 9Mb and 12.5Mb) - Checked on 2017-08-19 01:12:06
Current line speed:3.9 Mb
I did not change my home LAN/WAN configuration at all or add any new devices. My 'helpdesk' page on the router I will paste below. You can see from the stats I performed a router restart too. Thanks for any helpful suggestions! I wish I had more information to help work out the problem.
Thanks,
Chris
1 - Product name: Plusnet Router
2 - Serial number: #####
3 - Firmware version: 7.275.2_F2704N_Plusnet
4 - Board version: F@ST2704N
5 - Mode ADSL
6 - Uptime: 0 days 00:19:01
7 - Data rate: 736/4118
8 - Maximum data rate: 744/4380
9 - Noise margin: 5.9/8.5
10 - Line attenuation: 23.5/41.5
12 - Data sent/received: 13.3M/42.5M
20 - Broadband username: ########
21 - Wi-Fi network/SSID: PLUSNET-Q89KHN
22 - Wi-Fi connections: Disable(802.11 b/g/n(up to 144 Mb/s))20 MHz WPS enabled
23 - Wi-Fi security: WPA2
24 - Wi-Fi channel: Automatic (Smart Wireless)
25 - Firewall: Default
26 - MAC Address: 90:4d:4a:4f:ad:61
27 - Software variant Version 1.0
28 - Boot loader: 7.275.2
Moderator's note by Mike (Mav): Post released from Spam Filter.
1 REPLY
Fixes: 152
Re: Sudden reduction in speed since Sunday Afternoon
Sorry to hear you're having speed issues.
Our tests are showing a external fault on the line which we've raised with our suppliers.
We'll update you when we know more.
 Matthew Wheeler
