Sudden drop in Speeds at around 5pm
- Sudden drop in Speeds at around 5pm
16-02-2010 6:34 PM
I asked in the ticket if there was any known problems in my area, I have only one Bt socket in the property, its the new type with built in filter, it was fitted about two years ago, I have no extensions, the cable goes directly to my computer and a phone plugged in that's it nothing else, the router stats seem fine as far as I can tell, I will try to add a graph I took earlier if I can.
When I log on i have to wait ages to load a page, if someone from support can just check then tomorrow night if its the same I will take my computer down stairs and plug into back of BT socket, I done think that's the problem but something is definitely wrong, by the way I checked which gateway I was on and it came back gateway unknown if that's any help.
Today 17:08 131 kbps (16.4kB/s) 98 kbps (12.3kB/s) Share
Today 13:54 6548 kbps (819kB/s) 373 kbps (46.6kB/s) Share
Today 09:11 6609 kbps (826kB/s) 373 kbps (46.6kB/s) Share
Today 09:03 6577 kbps (822kB/s) 367 kbps (45.9kB/s) Share
Today 08:55 6588 kbps (824kB/s) 357 kbps (44.6kB/s) Share
Today 07:30 6568 kbps (821kB/s) 378 kbps (47.3kB/s) Share
Today 07:30 6563 kbps (820kB/s) 364 kbps (45.5kB/s) Share
Yesterday 19:50 132 kbps (16.5kB/s) 91 kbps (11.4kB/s) Share
Yesterday 19:07 130 kbps (16.3kB/s) 92 kbps (11.5kB/s) Share
Yesterday 16:43 139 kbps (17.4kB/s) 93 kbps (11.6kB/s) Share
Yesterday 07:14 6570 kbps (821kB/s) 349 kbps (43.6kB/s) Share
Yesterday 07:06 6569 kbps (821kB/s) 346 kbps (43.3kB/s)
regards
jono
Re: Sudden drop in Speeds at around 5pm
16-02-2010 6:52 PM
You are currently connected to the "Telehouse North, Juniper 2" gateway. This gateway is sometimes known as ptn-ag2.
I think i read an email today about this having trouble, if someone can verify please.
regards
jono
16-02-2010 6:58 PM
Was going to say have you got near to your limit and been clamped after 16:00, but you just spoilt that
16-02-2010 7:04 PM
Will wait and see if the support team get back to me.
Thanks for replying though.
regards
jono
16-02-2010 10:05 PM
http://usertools.plus.net/exchanges/
It's not unusual with maaf to have to hop gateways in order to find one that isn't sloooooow
17-02-2010 9:23 AM
regards
jono
17-02-2010 10:04 AM
17-02-2010 3:37 PM
I'll post back later.
thanks again
17-02-2010 4:20 PM
17-02-2010 7:06 PM
regards
jono
18-02-2010 7:13 PM
regards to all who gave advice
18-02-2010 10:09 PM
Quote I wonder why gateways have become an issue, having to change them by rebooting the router ? after 2 yrs of literally no probs.
The pipes seem to get out of balance more frquently than they used to, well they do on the maaf/PN network.
They keep lighting new segments so you wouldn't think there should be congestion issues if that is the case.
Alastair
