Sudden (but consistent) speed drop 19 July on - anyone else?
- Sudden (but consistent) speed drop 19 July on - an...
20-07-2015 8:09 AM
No logical explanation that I can think of - anybody else having a similar problem?
Re: Sudden (but consistent) speed drop 19 July on - anyone else?
20-07-2015 11:21 AM
Your description somewhat suggests you had a resynch at a lower speed. You need to gather information to determine why.
20-07-2015 1:37 PM
It looks like this has happened due to errors on the line.
I can reset it however ideally we need to track down what's causing the errors.
21-07-2015 8:22 AM
21-07-2015 10:16 AM
21-07-2015 12:03 PM
21-07-2015 12:23 PM
21-07-2015 12:46 PM
Your help with this is very much appreciated - thanks so much for taking the time and trouble to sort it out.
27-07-2015 11:10 PM
28-07-2015 9:11 AM
28-07-2015 9:51 AM
Quote from: Townman Your description somewhat suggests you had a resynch at a lower speed. You need to gather information to determine why.
Quote from: Matthew Your line has become banded to between 1 and 3mbps.
If a line has become banded, there is not much point unbanding it unless the reason for banding has been identified and fixed. Please follow the guidance in the speed issues thread or raise a broadband fault report - links below will help you.
29-07-2015 11:15 AM
Type Interleave Path
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 3064Kb 752Kb
Noise Margin 8 5
Output power(dBm) 128 162
Attenuation(dB) 67 30
Current line speed: 2.7 Mb
29-07-2015 2:33 PM
http://www.kitz.co.uk/adsl/max_speed_calc.php ; suggests 4.9km
29-07-2015 2:57 PM
30-07-2015 9:10 AM
Is the router in the master socket?
What router is it? Do you have another you can try?
Is there any noise on the line? Dial 17070 option 2.
Please run through the bb fault reporter - link below.
