Sudden Speed Drop
- Sudden Speed Drop
Sudden Speed Drop
22-06-2008 3:18 PM
I know there have been several threads regarding this issue, but I'm wondering if anyone else is experiencing the same problems as myself.
My internet speed was a between 6000 - 67000kbs up to Thursday last week since then it has dropped between 3000 - 1000kbs.
Today 15:04 3006 kbps (376kB/s) 356 kbps (44.5kB/s)
Nothing has changed to my set up (apart from install of Firefox 3).
My sync speed is still showing as 7000 Kbps.
I'm using a D-link DI604 Router and D-link 320T Ethernet modem . There has previously been a drop in speed occasionally if I have been 'Seeding' torrents throughout the night, but this has been rectified by a reset.
The current speed drop does not appear to be corrected by a hard reset on my modem
This the latest stats from my modem
ADSL Firmware Version: 5.00.04.00 - 5.00.03.00 - 5.00.03.00 Annex A - 01.07.2b - 0.52
ADSL Software Version: V3.00B01T02.UK.20060126
Line State Connected
Modulation ADSL_G.dmt
Annex Mode ANNEX_A
Max Tx Power -38 dBm/Hz
Item Downstream Upstream Unit
SNR Margin 13 27 dB
Line Attenuation 12 5 dB
Data Rate 8128 448 kbps
I have raised this a a possible fault but wondered if any one had any ideas while i was waiting.
Annex Mode ANNEX_A
SNR Margin 13 27 dB
Message 1 of 4
(1,027 Views)
3 REPLIES 3
Re: Sudden Speed Drop
23-06-2008 1:08 PM
Hi Cressa,
Could you possibly try running a BT Speedtest for us to see what sort of throughput levels you experience through that?
http://www.speedtester.bt.com
Message 2 of 4
(345 Views)
23-06-2008 7:22 PM
Hi
It does seem to have levelled out slightly from yesterday but im worried it could drop again
Recent speed test results are :
Test1 comprises of Best Effort Test: -provides background information.
IP profile for your line is - 7150 kbps
DSL connection rate: 448 kbps(UP-STREAM) 8128 kbps(DOWN-STREAM)
Actual IP throughput achieved during the test was - 4418 kbps
Message 3 of 4
(345 Views)
24-06-2008 11:28 AM
Hiya,
Things look pretty decent to me. You might actually be able to tweak things a little further to improve on that by following this link below:
http://www.plus.net/support/broadband/troubleshooting/rwin_video.shtml
Message 4 of 4
(345 Views)
