Substandard Force9
SOS
Substandard Force9
Now that Force9 Customers have to use PlusNet are then any plans to provide us with an equal system?
Ianwild
Re: Substandard Force9
What are you missing?
SOS
Wireless is missing.
Ianwild
Yeah, I had a feeling you would say that. I'm going to be brutally honest here: Our wireless product isn't currently everything it should be, and in it's current form isn't going to be expanded.
The problem, fundamentally, is that we don't offer all of the features of Openzone (Such as roaming to The Cloud) and to fix that we need to relaunch a new version of the product. That, you will be pleased to hear, is on our roapmap although I don't know when we might expect that.
Is there anything else, or was it just that you wanted (I may be able to find a way to provide this if it is of use)?
Ian
