Sub-standard performance on Pro/PAYG
- Sub-standard performance on Pro/PAYG
11-12-2009 6:22 PM
Could you provide the following information (Plusnet Pro or PAYG users only):
Edit: I'm going to update this post with a list of the users who appear to be affected (not all have posted to this topic)
chesterfield
bazdc2 http://community.plus.net/forum/index.php/topic,81852.0.html
Footys
martin2006
clarkec321
treg103 (confirmation as being Pro user received by PM)
rapalla (similar symptoms on Premier option 1)
Jarvo http://community.plus.net/forum/index.php/topic,81546.0.html
Thredz http://community.plus.net/forum/index.php/topic,81886.msg672162.html#msg672162
munkimatt
Re: Sub-standard performance on Pro/PAYG
11-12-2009 7:11 PM
11-12-2009 10:13 PM
And here it is just a few days ago right in peak time:
Router stats:
ADSL Link........................Downstream.......................Upstream
Connection Speed..........7520 kbps.........................448 kbps
Line Attenuation.....................33.0 db............................17.0 db
Noise Margin..........................7.7 db...............................18.0 db
BT speedtest result at peak:
Download speedachieved during the test was - 517 Kbps
Additional Information:
Your DSL Connection Rate :7712 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 7150 Kbps
Current line speed 7150
Not on 21CN
VP status is red - but has been for months - never affected me.
Problem started only a few days ago - everything was perfect until then.
12-12-2009 9:42 AM
sorry didnt read all your original post, my profile is 8128 nornally. speed test tthis morning also shown below at 6727
exchange is green. link below to other discussion
http://community.plus.net/forum/index.php?topic=80799.new;topicseen#new
12-12-2009 12:27 PM
- Broadband Pay As You Go
- Broadband Your Way Pro
- Plusnet Pro
If you're having speed problems and are not using one of those three products, please consider starting a new thread of your own or joining in on another thread that's applicable to your problem/product. Thanks.
12-12-2009 2:25 PM
12-12-2009 6:15 PM
Just as another point we thought of - could those having the problem advise what their logon domain is?
i.e. ********@plus.net, or *******@plusdsl.net
Mine is "plus.net"
12-12-2009 6:37 PM
Here is 3 mybroadbandspeedtest - at hardly peak times of the day
My router is the standard PN D-Link 2640B and the stats are:
Have followed a few steps as advised in the previously mentioned thread
It says
You are currently connected to the "Telehouse North, Juniper 6" gateway. This gateway is sometimes known as thn-ag1
Have powered down and left for 5 mins
Booted back up and it says (although I've been on 2 or 3 gateways the past 3-4 days of this problem, and it hasn't had a positive effect on the results)
And these are the new router stats
and I'm "You are currently connected to the "Telehouse North, Juniper 5" gateway. This gateway is sometimes known as thn-ag2"
Have just left it alone for a few hours and have just got this mybroadbandspeed result
Any help or advice would be much appreciated - and is in fact greatly needed
Thankyou
12-12-2009 8:20 PM
12-12-2009 9:28 PM
Just registered on this site since I've been experiencing exactly the sort of problems being discussed here. About 3 days ago I've gone from being able to reliably download at 400 - 500 KBps (4Mbps) to max of about 50KBps (400Kbps). These speeds also seem to echo results from various broadband speed testers, including the mybroadbandspeedtest and speedtester.bt.com. I phoned PlusNet support this evening and was told that their network, the exchange and my line all looked absolutely fine to them and it was potentially my router. I'll be trying to beg and borrow one from the neighbors but they aren't around at the moment so I can't test that theory.
According to the PlusNet site my current line speed is 6500, which is pretty close to my routers report of 7328Kbps, the VP status for my exchange is green and has been for some time, and my domain is @plusdsl.net.
[Edit]
I've been on the Pro account for the last few weeks having upgraded from the value account. Everything was fine up until a few days ago.
12-12-2009 10:48 PM
to 4-4.5 at peak times. However in recent days I get large fluctuations during offpeak and in the evenings it has dropped down to between 300-500k.
Something has happened to disturb the peace for sure.
13-12-2009 12:31 AM
Quote from: chesterfield Thanks for the time on the phone today John. It was an interesting chat.
i input @plusdsdl.net when i run bt speedtester if that helps
13-12-2009 12:33 AM
13-12-2009 12:46 AM
I think its becoming clear that there was s change on the network on or around 4/5 days ago that has caused a number of us to start seeing these errors. What was initially looking like my issue with a busy exchange now looks to be considerably more wisespread. The login domain and its routing seems not to be the difference which is one more thing ruled out.
I think we need to look at the differences between a connection not suffering (Jelv) and one that is (anyones here including mine). Once we can list the differences, we need to look at the changes PN have made on or around the time we all started suffering this issue and PN can then move to fix it.
Conceding there is actually a fault rather than having us all trying to resolve this individualy would be a start....
Ive been searching through the status updates for anything relating to the time this fault started appearing, which, going by my last "good" speed test, appears to be on or around the 8th of December, and I found this one:
Quote Planned Transit Maintenance - Tuesday 8th December 2.30pm-5.00pm
When's this work happening?
This afternoon, 8th December.
What does it affect?
The route some of your traffic takes across the Internet.
How long will it take?
About fifteen minutes.
What does the work involve?
We will be routing some customer traffic via a newly established peering arrangement.
Is there any more detail available, as this is looking the most likely suspect for now.
It appears as those affected are having all their traffic either classed as bronze, or unclassified at all - hence the enormous drop at peak time.
13-12-2009 12:57 AM
