Stupidly slow speed making the Internet unuseable...
- Re: Stupidly slow speed making the Internet unusea...
31-03-2014 10:57 AM
For the past 14 hours I have been experiencing really slow speeds. No idea what's going on...
Here are some stats...I hope someone can give me some idea as to what's happening...? Plusnet?
DSL Connection
Link Information
Uptime: 0 days, 0:15:51
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 1.888
Data Transferred (Sent/Received) [MB/MB]: 1,32 / 10,29
Output Power (Up/Down) [dBm]: 12,6 / 16,6
Line Attenuation (Up/Down) [dB]: 31,5 / 59,5
SN Margin (Up/Down) [dB]: 13,0 / 15,4
Loss of Framing (Local/Remote): 0 / -
Loss of Signal (Local/Remote): 0 / -
Loss of Power (Local/Remote): 0 / -
Loss of Link (Remote): -
Error Seconds (Local/Remote): 0 / -
FEC Errors (Up/Down): 17 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): - / 0 / 0
Download speed is at about 0.16mbps
Fed up.
DSL Connection
Link Information
Fed up.
Message 1 of 9
(1,199 Views)
8 REPLIES 8
Re: Stupidly slow speed making the Internet unuseable...
31-03-2014 2:27 PM
18 hours and counting....
Message 2 of 9
(791 Views)
31-03-2014 2:33 PM
Hi Thumb866,
I've taken a look at your line and can see that you've got an intermittent issue which is the probably cause for the very low speeds.
Are you able to swap the microfilter for an alternative and connect that into your Test Socket?
Message 3 of 9
(791 Views)
31-03-2014 2:48 PM
Not able to do that as I cannot seem to find an alternative microfilter...
Message 4 of 9
(791 Views)
31-03-2014 3:20 PM
Are you able to borrow one at all?
We just want to ensure it's nothing internal before raising this to our suppliers for further investigation. If you have a router we sent you, you should have received 2 microfilters with it.
Message 5 of 9
(791 Views)
31-03-2014 5:00 PM
No. I can't get hold of one.
I guess its just a waiting game/hoping that it sorts itself out then? It has corrected itself each time its done this before...
Message 6 of 9
(791 Views)
31-03-2014 5:19 PM
It'd be worth raising a fault with us at http://faults.plus.net however, you will be asked to swap the microfilter over at some point as this could be what's causing the problem.
Message 7 of 9
(791 Views)
07-04-2014 4:06 PM
awfully slow speeds are back.
this is happening way too frequently....The test socket/microfilter swap made no difference.
Message 8 of 9
(791 Views)
07-04-2014 4:09 PM
Thanks for letting us know.
Can you please raise a fault <a href="http://faults.plus.net">online</a> so that our Faults Team can get this looked into for you?
Message 9 of 9
(791 Views)
