Stuck on Step 3: Finishing setup
scottgroovez
I've had fibre installed on Wednesday, but the router setup is stuck on step 3. I can browse to plusnet site OK, but any other site takes me to the setup screen.
Fixes: 260
Re: Stuck on Step 3: Finishing setup
welcome to the forums Smiley
Might be worth giving them a call to help get the activation finished off
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
ScottStorey
Hi scottgroovez,
Thanks for your time on the phone.
As discussed you are now online, the account was all activated but it seems that the routers automatic setup was not completing successfully and the router appears to be faulty as it keeps logging you out whenever you click connect on the manual setup.
I've dispatched a new router for you and set you up on a PPPoE connection so you can get online until the new router arrives.
Cheers,
Scott
