Stuck on 40/10
thumbsdown
Stuck on 40/10
Just had by internet activated today., however, I'm stuck on the 40/10 profile. When will the be updated to 80/20?
16 REPLIES 16
Legend
Fixes: 294
Re: Stuck on 40/10
I assume, if you have only just joined, that you are on the 'Fibre' package. What does https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome give as your expected speeds? Obscure your address in the reply.
thumbsdown
Re: Stuck on 40/10
I've un-joined and re-joined, was on the 'Business Fibre' package until a couple of weeks ago.
Legend
Fixes: 294
Re: Stuck on 40/10
A full sight of that page would be useful. What did you get on tour previous package?
thumbsdown
Re: Stuck on 40/10
Legend
Fixes: 294
Re: Stuck on 40/10
OK. Looking at that, you should still be getting it. What are you getting on a speed test now, and what did you get previously?
thumbsdown
Re: Stuck on 40/10
I should. But currently capped to 40/10. Hence why I'm here.
Legend
Fixes: 294
Re: Stuck on 40/10
My best suggestion - if you get a good agent - is to ring them and ask them to reset your connection.
Fixes: 462
Re: Stuck on 40/10
@jab1 Not sure that's going to help John.
From those line stats it looks suspiciously like the line's been provisioned on a 40/10 profile.
@thumbsdown what Plusnet product are you on, is it Fibre (without a phone service) or Unlimited Fibre with phone ?
It all seems a bit strange ?? , AFAIK Fibre is aways provisioned on 80/20 and Unlimited Fibre is no longer available to new customers due to Openreach 'WLR Stop sell'
Fixes: 1,614
Re: Stuck on 40/10
Hi @thumbsdown
I'm sorry to hear you're having speed issues.
I've placed an order to fix the profile, which should complete within 24 hours.
See if your speed has increased after then. Smiley
Legend
Fixes: 294
Re: Stuck on 40/10
@MisterW Understand what you are saying. Maybe my post was a bit lacking in clarity. I too understand that 'new' provisions on 'Fibre' should be provisioned on 80/20, so don't understand why the OP appears to be on 40/10.
I was, somewhat clumsily, saying they need to be provisioned properly.
Fixes: 462
Re: Stuck on 40/10
@jab1 Sorry if I misunderstood, I thought you were suggesting asking for a DLM reset. If the line is provisioned incorrectly then no amount of DLM resetting is going to work. Support need to check the line provisioning and not just on the PN systems, but also the Openreach ones!!
Legend
Fixes: 294
Re: Stuck on 40/10
@MisterW See @Gandalf 's post - I reckon he's spotted and corrected someone's error. 😀
Fixes: 1,614
Re: Stuck on 40/10
'Twas a robot's error. I've flagged it up for investigation internally.
Fixes: 462
Re: Stuck on 40/10
@jab1 hadnt seen that, it was posted while I was typing (I hate this forum not notifying you of that!!!)
Wizard to the rescue😀
