Stuck Profile - and Interleaving question
- Stuck Profile - and Interleaving question
08-02-2010 10:16 PM
Now, it's been a while since I looked at the state of my line, even though I have something that collects the line statistics regularly, but I was a little surprised to see that my profile rate had dropped to 6000 for the last year (had been 6500 for ages before that)
The connection speed seems to have been absolutely stable at 7616 down, and 448 up. But the profile rate dropped from 6500 to 6000, and doesn't seem to have ever restored.
Can we give it a flick?
I also wondered whether we should try removing the interleaving too. Does anyone reckon the line stats below will live with it?
That's a 4 day slice of the stats, but it shows a pretty average set of data.
I figure the steps in the downlink noise margin must be a neighbour's ADSL being turned on & off. I haven't found anything in our house that switches at the same time, and you can get a week or two go by where it doesn't step down at all.
Cheers,
Mike
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Re: Stuck Profile - and Interleaving question
08-02-2010 11:48 PM
Does your router almost always sync at 7616kbps? Removing interleaving might allow that to go higher. One needs to be aware of error rates to form an opinion on whether removing interleaving is likely to have a detrimental effect on throughput.
Has your exchange been enabled for 21CN? The current Plusnet Premium and Pro products offer up to 20Mbps ADSL2+ where 21CN is available.
09-02-2010 3:12 AM
Why the difference between the two? They ought to track each other, shouldn't they? Well, they used to...
The router always syncs at 7616, and I don't suffer from disconnections - unless I reboot it because something funny is happening on the LAN side. I had a connection time of just over 4 months last summer.
On the error front, I just started up RouterStats (it's been a while), and got these figures out. It's a Netgear 834GT.
[tt]
SF: 6095634
SF Errors: 32
Reed Solomon: 414339895
RS Corrected: 8711
RS Un-corrected: 283
HEC: 29
Errored Seconds: 25
Severe ES: 0
Interleave Depth: 16
And totals of
CRC: 32
LOS: 0
LOF: 0
ES : 25
[/tt]
They look to be over a 28 hour period. I guess that's about 1 error per hour... doesn't sound too bad 😉
Our exchange is due to go 21CN in the next 6 weeks. It is what made me start considering the impact of changing service in the first place! It was one of the early exchanges with ADSL originally, almost 10 years ago, and I was the first to be turned on there, but has been a bit slower on this round.
Mike
09-02-2010 1:03 PM
I can't see any updates on BTs side since November, which in part is a good thing (it means your connection rarely if ever reconnects so is very stable) but also in part means your profile won't update.
We could remove interleaving, it looks like your line would be fine without - this might also force a refresh of the BT profile that we could then match on our side.
If that doesn't help we could try for an SNR reset but as that starts the 10 day training period again I suggest that we leave that as a last resort sort of thing if the removal of interleaving doesn't sort things out.
Another thing that might work (if you don't want interleaving off) would be to deliberately resync the router once a day or so, preferably late morning, in order that the exchange picks up resyncs at a higher speed and uplifts the profile to match. This should happen within a few days.
Hope that helps, it should certainly offer some options anyway. Please let us know if there's anything we can do.
09-02-2010 11:52 PM
I've looked at the line stats today, and not seen much - so I think I'll go with turning off interleaving, and see what happens.
Can you do it from this, or should I raise a ticket?
Cheers,
Mike
10-02-2010 12:11 AM
10-02-2010 12:55 AM
10-02-2010 2:24 PM
10-02-2010 4:26 PM
Mike
11-02-2010 2:03 PM
11-02-2010 4:21 PM
Went through at about 2:30 this morning.
The connection restored at 8128, and has stayed up since then. The line stats over yesterday & today are attached.
I haven't attached RouterStats yet (it interferes with my other graph) to see the CRC details, so can't tell if it is happy, or just on the edge.... I'll check those out later.
However, my profile doesn't seem to have changed yet. At BT is seems to be 6500, and at PN it seems to be 6000.
Mike
11-02-2010 4:52 PM
11-02-2010 5:02 PM
I guess if I want the BT end to notice, I either have to wait (just in case 1 year wasn't enough), or do as Matt suggests - keep resetting once per day, or go back to a new training period.
Mike
12-02-2010 2:55 AM
I'm mainly watching the CRC, ES (and SES) and SFErr figures. They look higher than I was getting just before the switch, but they don't look like anything to be concerned about right now.
I guess these figures cover around 1 day...
[tt]
# adslctl info --stats
adslctl: ADSL driver and PHY status
Status: Showtime Channel: FAST, Upstream rate = 448 Kbps, Downstream rate = 8128 Kbps
Link Power State: L0
Mode: G.DMT
Channel: Fast
Trellis: ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 9.3 22.0
Attn(dB): 30.0 19.0
Pwr(dBm): 19.8 11.9
Max(Kbps): 8960 1048
Rate (Kbps): 8128 448
G.dmt framing
K: 255(0) 15
R: 0 0
S: 1 1
😧 1 1
ADSL2 framing
MSGc: 1 1
B: 239 15
M: 1 8
T: 1 1
R: 16 16
S: 9.0000 9.0000
L: 1920 128
😧 16 2
Counters
SF: 3241165 3241163
SFErr: 283 8
RS: 0 0
RSCorr: 0 0
RSUnCorr: 0 0
HEC: 183 2
OCD: 1 0
LCD: 0 0
ES: 481
SES: 4
UAS: 40
Total time = 1 days 4 hours 27 min 11 sec
SF = 5102257
CRC = 618
LOS = 0
LOF = 0
ES = 481
Latest 1 day time = 4 hours 27 min 11 sec
SF = 943044
CRC = 54
LOS = 0
LOF = 0
ES = 52
Latest 15 minutes time = 12 min 11 sec
SF = 43050
CRC = 3
LOS = 0
LOF = 0
ES = 3
Previous 15 minutes time = 15 min 0 sec
SF = 52930
CRC = 0
LOS = 0
LOF = 0
ES = 0
Previous 1 day time = 24 hours 0 sec
SF = 4159213
CRC = 564
LOS = 0
LOF = 0
ES = 332
15 minutes interval [-30 min to -15 min] time = 15 min 0 sec
SF = 52931
CRC = 3
LOS = 0
LOF = 0
ES = 3
15 minutes interval [-45 min to -30 min] time = 15 min 0 sec
SF = 52989
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-60 min to -45 min] time = 15 min 0 sec
SF = 52872
CRC = 0
LOS = 0
LOF = 0
ES = 0
[/tt]
Cheers,
Mike
12-02-2010 12:01 PM
Certainly looks nothing to worry about, if the line stays stable but your profile doesn't increase in a week or so I'd say we should go down the SNR reset route.
