Stuck IP Profile
ITWorks
Fixes: 9
Stuck IP Profile
Hi
A customer a recently moved over to PN should be getting an ip profile of 7.15mb, its stuck at 2mb.
Would appreciate if some one could take a look Smiley , ticket #66779091
Regards
Mike
16 REPLIES 16
Pettitto
Fixes: 5
Re: Stuck IP Profile
Yep - Leave it with me and I'll take a look.
ITWorks
Fixes: 9
Thanks Chris, much appreciated Smiley
Regards
Mike
ITWorks
Fixes: 9
Hi Chris
Has you been able to take a look at this?
Regards
Mike
ITWorks
Fixes: 9
I see from the ticket that has just been updated that an SNR reset has been done, will monitor and hopefully this will sort the problem.
Regards
Mike
Pettitto
Fixes: 5
Hi Mike,
Yes, if the SNR Reset doesn't do the trick, I'll speak to our suppliers and see if we can get the bRAS changed manually.
ITWorks
Fixes: 9
Hi Chris
Unfortunately the SNR reset has not worked (see attachment).
Regards
Mike
Pettitto
Fixes: 5
Really sorry about this Mike.
I'm just looking to see what I can do for you.
goldenfibre
Seasoned Pro
Fixes: 12
look like bt had to do it manual bras profile to get rid of stuck 2Mbps. It happen to me before as BT had to manual it.
Pettitto
Fixes: 5
That's what I am attempting now. An SNR Reset was pushed through before I got a chance to do it last time putting the line into a new training period again...
Edit:
Looks as though my charm has worked, should be all good to go in the next 5 minutes.
goldenfibre
Seasoned Pro
Fixes: 12
How to get bt speedtester page ? BT had taken off the old page it gone!
Pettitto
Fixes: 5
goldenfibre
Seasoned Pro
Fixes: 12
It not showed any ip profile rate page ?? Where can I get it from ?
Pettitto
Fixes: 5
Click the 'Further Diagnostics' link and complete the further test.
goldenfibre
Seasoned Pro
Fixes: 12
Thanks Chris, it was hidden by Further Diagnostics link. BT Wholesale making it harder to find where is it ?
Result below.
