Stuck IP Profile
- Re: Stuck IP Profile
Stuck IP Profile
07-03-2013 3:49 PM
A customer a recently moved over to PN should be getting an ip profile of 7.15mb, its stuck at 2mb.
Would appreciate if some one could take a look , ticket #66779091
Regards
Mike
07-03-2013 4:14 PM
Yep - Leave it with me and I'll take a look.
07-03-2013 4:16 PM
Regards
Mike
08-03-2013 10:28 AM
Has you been able to take a look at this?
Regards
Mike
08-03-2013 10:45 AM
Regards
Mike
08-03-2013 10:58 AM
Yes, if the SNR Reset doesn't do the trick, I'll speak to our suppliers and see if we can get the bRAS changed manually.
11-03-2013 3:04 PM
Unfortunately the SNR reset has not worked (see attachment).
Regards
Mike
11-03-2013 3:40 PM
I'm just looking to see what I can do for you.
11-03-2013 3:43 PM
11-03-2013 3:44 PM
Edit:
Looks as though my charm has worked, should be all good to go in the next 5 minutes.
11-03-2013 3:54 PM
11-03-2013 3:57 PM
11-03-2013 4:05 PM
11-03-2013 4:06 PM
11-03-2013 4:14 PM
Result below.
