Stuck ADSL profile
jamman
Stuck ADSL profile
Hello, We have been synced at 3008 for the past 34 days but speed tests still show us having a 2mb profile when it should be 2.5mb. We have been having problems where if 2 computers are using the internet at the same time then the internet slows down a lot. Is it possible for you guys to contact BT and get this stuck profile fixed?
Fixes: 163
Re: Stuck ADSL profile
I'm taking a look now, I'll post back shortly.
 Chris Parr
 Plusnet Staff
Fixes: 163
Your profile updated at 2014-12-04 03:58:19 - can you log in to the router and do a single disconnect/reconnect? Let me know what speeds you're seeing on a speedtest after doing this.
 Chris Parr
 Plusnet Staff
jamman
Ah good, I did as you said and we are now on 2.5mb once again, So the problem was our end, thanks for the help!
Fixes: 163
Great, thanks for letting me know that it's sorted.
 Chris Parr
 Plusnet Staff
Fixes: 26
Quote from: Chris
Hi Chris,
Does this indicate that the profile update - drop PPP interlock thought to be fixed is still failing?  Wink
Kevin
Fixes: 163
It does indeed, but the person looking in to it isn't in the office this week. I've got a few things to pick up with him when he's back.
 Chris Parr
 Plusnet Staff
