StreetStats, Compare broadband speeds on your street, and in your locale
- StreetStats, Compare broadband speeds on your stre...
25-04-2012 3:08 AM
http://www.uswitch.com/broadband/speedtest/streetstats/
For Plusnet, Internet House, 2 Tenter Street, Sheffield, S1 4BY
Near me ...
(BT Exchange is 466 metres away)
My copper speed, with Plusnet, is faster than 100% of other providers, non Fibre
Surprised at the variations.
Re: StreetStats, Compare broadband speeds on your street, and in your locale
25-04-2012 7:33 AM
Mine done when I swapped to ADSL2+ was never plotted - though I have a copy of the test result it came back with.
If I select "tests only in the last month" from the drop down box and then pan round the area including a large city I find that apparantely none at all were done anywhere............this actually means lots were done but none were recorded and mapped.
I even tried looking at London in the last month - no tests done - yeah I'll believe that - not.
So it's actually a currently non functional site
25-04-2012 7:40 AM
Interestingly, one test just across the road from the exchange (a few yards away) has a BT (Retail) test of only 11.1Mbps.
A lot will depend on what packages people are on and probably the time of day the test was run, as well as the quality of the user's setup.
25-04-2012 8:09 AM
They have removed the 'pin' on the map which shows the local exchange as well.
You used to be able filter the results by your local exchange or all exchanges - now its just all exchanges and the locations of the individual exchanges have been removed - so it's now impossible to see whether those close to the exchange are getting better speeds on average................
25-04-2012 8:59 AM
If you click on a "flag" it gives you exchange information, including distance, even though metres is spelled incorrectly, and doesn't quite tally with BT indication.
Sam Knows, Kitz, amongst others, will give you your local BT Exchange postcode, and you can centre the map there.
Such as this local BT Exchange
Mine is just down the hill from where I live.
25-04-2012 9:54 AM
on copper till next week
25-04-2012 10:05 AM
Quote from: PlusComUK ..........If you click on a "flag" it gives you exchange information, including distance, even though metres is spelled incorrectly, and doesn't quite tally with BT indication.
Sam Knows, Kitz, amongst others, will give you your local BT Exchange postcode, and you can centre the map there..................
Yep, do all that quite regularly. You can also input the "exchange code" in some places. Samknows shows the code as does the Usertools Exchange Status checker, no doubt amongst others.
25-04-2012 10:11 AM
25-04-2012 10:15 AM
[Edit] you need to zoom in or enter a postcode, then click on enable for Speedtest Results.
25-04-2012 10:43 AM
Bob.
25-04-2012 3:36 PM
One severely underestimates distances in the region of 50% . That cold be because of users going FTTC, but from the short time it ha been available (end 2011) I doubt that is a major factor. The connection type mix also makes averages unreliable.
On the other I looked at simple 2 test post codes. There it is clear that again there is a mixture of suppliers and connections; ADSL (all flavours and FTTC. From them it seems that they are using a crude arithmetical mean. Now how do you, or can you find an average for a box of mixed fruit.
IM(FWIW)O without considerable refinement teh data is near meaningless, if not misleading.
25-04-2012 3:44 PM
27-04-2012 11:31 AM
10-05-2012 11:38 AM
Quote from: x47c The uswitch street stats site seems not to be accepting new tests for some time now.
Update:
Uswitch have now removed the options to view "tests only in the last month".
Previously you could view all, last 3 months and last month's tests only - now the entire drop down box has gone so you get no option to filter the tests at all by any criterion.
Now, as I previously reported it seems that Uswitch is not updating their site anymore with up to date tests result done on the site - though you can still do the test.
Previously using this "view tests in last month only" option allowed you to see that nothing had been updated in the last month anywhere in the UK and therefore that the site was not updating.
Now you can't see this fact....so you are unaware of it.
So the casual viewer will think that these listed tests are all current tests - when they are not.
Why do these corporates think they can be clever and the people will not notice.........
