Streaming
masive39
Streaming
I would like help! please can anyone tell me what would be the best settings for the firewall on my broadband as I use it for streaming ? hope someone can help thank you in advance .
Fixes: 257
Re: Streaming
You shouldn't we'd to adjust your firewall at all to watch streams from iPlayer / Netflix etc. As you initiate the connection or do you wish to be able to stream something like a security camera when you're not at home?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 456
Re: Streaming
I concur with dvorak.
Are you experiencing any problems via streaming? If so, are you using a wired or wireless connection?
Thanks,
masive39
Re: Streaming
I'm using the vpn to watch movies
Fixes: 456
Re: Streaming
Do you have any problems whilst streaming without a VPN?
masive39
Re: Streaming
no, just with everyone on you tube saying when streaming anything there should be a vpn used to protect yourself.
