Strange behavior
- Re: Strange behavior
Strange behavior
27-12-2009 4:30 PM
I've been having stange speedtest readings for a few days, I do one per day and am getting a long slow constant (520kbps) reading and then a burst that goes from 2,500 up to 22,990 on down load, my upload remains the same at about 350, can anyone tell me whats causing this, its also taking a long time to load or refeash a page.
Message 1 of 6
(1,206 Views)
5 REPLIES 5
27-12-2009 4:45 PM
a) what speed tester are you using?
b) do you know what your router is showing? see here for how to get them http://www.kitz.co.uk/adsl/frogstats.php
C) the PN preferred speed tester is http://www.mybroadbandspeed.co.uk/ sometimes it does through a wobbly, but if you do another straight away that is normally correct
Message 2 of 6
(457 Views)
27-12-2009 5:01 PM
What antivirus software are you using ?
I changed to Kaspersky a few months ago and I get apparently very fast bursts of speed - whcih stops when I temporarily disable a/s.
Message 3 of 6
(457 Views)
27-12-2009 9:13 PM
I've just updated to KIS 2010 and mybroadbandspeed.co.uk is more erratic than on my previous KIS version
Correction. I've just tried Speedtest.net and it's results are just as stupid.
Message 4 of 6
(457 Views)
27-12-2009 10:12 PM
According to my router I'm getting 1920/448 and oddly enough I've just changed to Kaspersky as its free with Barclays, I'm thinking I may change back to AVG.
Thanks all.
Thanks all.
Message 5 of 6
(457 Views)
27-12-2009 10:14 PM
Apart from this odd quirk, I like Kaspersky -
it doesn't affect real download speed - in my experience - just the speed testers - But I would be interested in others experience.
Message 6 of 6
(457 Views)
