Strange Connection Problems ...
- Strange Connection Problems ...
21-07-2010 5:43 PM
hiya folks, I have been a Plusnet customer for about 4 months and have found the service to be very good and reliable up until recently ...
about 3 weeks ago I could't connect to the internet at all, no matter what I did the connection seemed to be dead, I reset the router (which was very hot) and checked all my settings but nothing I did got me connected - next day all was fine.
Now I am finding on some sites, or if I click a link I get a dialogue box popping up saying "Dial Up Connection" and I get the option of connecting to my broadband settings, if I do so it will just dial out and not connect because I am already connected to the internet - it will then select "Work Offline" in internet explorer either that or the connection to that page will be very slow. Now the strange thing is I can have a torrent or a download going in the background and the connection is doing just fine ... does anybody have any idea why my broadband seems to want to try and connect up when I am already connected?
I am using the supplied Plusnet (Thompson) router which is wired to my pc for what it is worth.
Message 1 of 3
(790 Views)
2 REPLIES 2
Re: Strange Connection Problems ...
21-07-2010 5:49 PM
hi david
start up Internet Explorer
on its menu bar , select tools / internet options / connections
make sure option 'never dial a connection ' is selected
try everything again
Message 2 of 3
(336 Views)
22-07-2010 4:38 PM
Hi David,
I'm quite confident that magnetism2772 has given you some appropriate advice there. If you're still struggling with this it may be a good idea to give support a call on 0845 1400200.
Message 3 of 3
(336 Views)
