Strange BT wholesale Speed Test Data
rhydsnewi
My ADSL line finishes its 10 day training period today, but is still running at a very odd 2.4 Mbit/second
Here are the line/router stats (Down/Up):
Sync speed 8128 kbit /448 kbit
line attenuation: 3.5 dB / 2.5 dB (its a very short line)
Noise margin 14.8 dB / 23 d/B
The BT wholesale speedtester bring back the following information:
Download speedachieved during the test was - 2.41 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 6.5 Mbps
Is there any reason why my connection isn't reaching the IP profile set for it? Will it get better now that training is over?
9 REPLIES 9
xreyuk
Re: Strange BT wholesale Speed Test Data
What is your current line speed in the plusnet member centre?
rhydsnewi
Current line speed:
    2.5 Mb
Oldjim
Resting Legend
Fixes: 63
That needs fixing - a phone call will be the quickest as it won't change by itself as there is very unlikely to be a delta report from the exchange
Basically ask for the Plusnet profile to be changed to match the BT profile
One that is done you may need to disconnect/connect via the router interface http://192.168.1.254/cgi/b/bb/?be=0&l0=2&l1=-1 to make it effective
rhydsnewi
Thanks for the info. The BT profile is a bit low IMO considering the quality of the line, would they be able to fix that too?
Oldjim
Resting Legend
Fixes: 63
not easily
that should sort itself out within 3 or 4 days but if it doesn't then post on here and the team on here will be able to get it fixed
I have assumed that 21CN isn't available at your exchange - this will check http://usertools.plus.net/exchanges/
Pettitto
Fixes: 5
I've updated the Speed Profile for you. You may need to log into your router and press the 'Disconnect' and 'Connect' button for the changes to take effect.
rhydsnewi
Quote from: Oldjim
not easily
No, our exchange is still on 8mbit ADSL max. Fibre is going in this year however.
rhydsnewi
Quote from: Chris
Thanks chief! I'll check when I return home this evening.
rhydsnewi
I checked the speeds after I returned home and restarted the router. We're up to a nice steady 6mbit. I'll let the line train for a while longer before chasing a DLM profile jump up to 7.15.
