Stop Technicolor Router showing as media device/ server on network
PhyllisTyne
Is there any way of doing this? I can't see a setting and would like the pesky thing not to show up on all of my clients.
PT
10 REPLIES 10
adamwalker
Fixes: 221
Re: Stop Technicolor Router showing as media device/ server on network
We've just been discussing that and my colleague Matt should be along shortly, he tells me we should be able to find this out Smiley
 Adam Walker
mattturner
If you log in via Telnet you can run these commands. I had to run the enable command first before disabling... (dont ask me why!)
:contentsharing upnpav config state enabled
:contentsharing upnpav config state disabled
If you have trouble then we can do this remotely for you if needs be.
Let me know how you get on.
Matt
PhyllisTyne
Remote would save me the aggro. I look forward to it disappearing  Smiley
mattturner
Abracadabra, and it's done!  Cool
PhyllisTyne
And its gone - thank you Santa Grin
Fixes: 160
Quote from: Matt
Does this mean that by default, PN has admin access to all Technicolor Routers?
mattturner
Yes we do with all the devices we ship to our customers, via a service known as TR-069.
We use this to auto configure the username and password into the router when they are first set up.
Wikipedia has a good overview here: http://en.wikipedia.org/wiki/TR-069
Matt
bigbolam
The router firmware update that I have recently had applied also seems to take care of this issue.
PhyllisTyne
Well after the recent outage I was getting authentication problems so ran the setup wizard again on the router. Technicolour now shows up again as a media device.
Can you fix or provide updated firmware so it goes away again please?
orbrey
Matt should be back in on Wednesday - I'll point him in the direction of this thread then, he should be able to help there.
