Still waiting for response.!!!
- Re: Still waiting for response.!!!
13-11-2011 11:59 PM
REF.TICKET NO : 48620234
Line has been slow like this since 28/10/2011 and appears to be stuck. I have tried a couple of router resets,the last reset at
22.40 on the 12/11/2011. The previous reset on the 05/11/2011 after line had been stable for 6 days. Both resets have shown similar stats. as attached
ADSL line status
Connection Information
Line state Connected
Connection time 1 days, 00:50:59
Downstream 1,664 Kbps
Upstream 448 Kbps
ADSL Settings
VPI/VCI 0/38
Type PPPoA
Modulation G.992.1 Annex A
Latency type Interleaved
Noise margin (Down/Up) 7.5 dB / 17.0 dB
Line attenuation (Down/Up) 58.7 dB / 31.5 dB
Output power (Down/Up) 2.6 dBm / 1.5 dBm
This Test comprises of Best Effort Test: -provides background information.
Download Speed
263 Kbps
0 Kbps 2000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 263 Kbps
For your connection, the acceptable range of speeds is 800-2000 Kbps.
IP Profile for your line is - 1468 Kbps
ADSL line status
Upstream 448 Kbps
ADSL Settings
VPI/VCI 0/38
Type PPPoA
Download Speed
263 Kbps
0 Kbps 2000 Kbps
Message 1 of 5
(1,080 Views)
4 REPLIES 4
14-11-2011 10:10 AM
Hi AMX,
I can see from line tests that the line is capped at 350kbps at present. The line is quite stable at the moment so I've submitted an SNR reset which should help retrain the line. The process should start within the next couple of hours so I'll make sure I check back around midday to see how things look. If not I'll see where we can take things next.
Message 2 of 5
(507 Views)
14-11-2011 12:22 PM
Message 3 of 5
(507 Views)
14-11-2011 2:03 PM
Thank you, all back to normal again.
Message 4 of 5
(507 Views)
14-11-2011 3:54 PM
Message 5 of 5
(507 Views)
