Still not up and running despite have email confirmation
Tbalderstone1
After weeks and weeks of waiting for an engineer to get my line sorted, Thursday they came and said it would all be up and running by midnight that night - sadly not to be.
Nothing yesterday and still have the broadband light flashing on my hub today.
I have reset the hub multiple times and unplugged/plugged everything back in but still having the same issues.
I’ve received texts and emails confirming that my line is all working but it is not.
Has anyone else had a long wait time for after the line is sorted to being connected and online?
Cheers
18 REPLIES 18
Fixes: 334
Re: Still not up and running despite have email confirmation
@Tbalderstone1 What other LEDs are lit on the Hub? Have you checked that the Broadband User Name at line 12 of your Hubs Help Desk is showing your 'username' and not 'setup'?
Tbalderstone1
Thanks for the reply, jab1.
No other lights at all just the flashing broadband in an orange colour.
Where can I find the hub help desk? I’m not too sure what mean here sorry
Fixes: 334
OK, @Tbalderstone1 . It sounds like your Hub may have the wrong 'username', which will prevent connection. I will post a picture below which will hopefully help, but post back if it doesn't.
Tbalderstone1
I don’t think I can access this page as I haven’t been able to set up the router yet as the broadband isn’t working.
It just comes up with a troubleshooting page that doesn’t help after trying everything.
Fixes: 334
If you have the Hub connected, to access that page, type '192.168.1.254' into the address bar of your computer, without the quote marks, hit enter and your Hubs Home page should come up - it is independent of a working broadband connection.
Tbalderstone1
1. Product name: Plusnet Hub
2. Serial number: +081441+NQ12500373
3. Firmware version: Software version 4.7.5.1.83.8.263 Last updated Unknown
4. Board version: Plusnet Hub One
This is what I get, means nothing to me sorry 😂
Fixes: 334
Apart from the fact that you are on an old firmware, those four lines tell me nothing either - there are a lot more lines below there witch may tell us more- is it possible to take a screenshot and attach it to a post?
Tbalderstone1
Here we go, thanks very much for giving me a hand with all of this.
Fixes: 334
Thanks for that - it appears (1) that you are not connected to the internet at all and (2) your hub won't authenticate anyway - it has the wrong  user credentials.
Try this:-
On the Home page under My Services you will see the current Broadband Username. If it’s setup@plusdsl.net then it has not been configured by PlusNet authorisation systems.
First try a factory reset of the hub by pushing a paperclip or similar into the reset hole and hold the switch closed for at least 20 seconds, the LED should turn green and then release
Leave the Hub One for around 10 minutes and check Home page for correct Broadband Username <your username>@plusdsl.net
If it still shows setup@plusdsl.net follow these steps.
Navigate from the Home page to >Advanced settings (you will be required to enter the Hub One admin password this found on bottom of the Hub or card with WiFi password).
Click on Continue to Advanced Settings then >Broadband >Internet
This page details your broadband Internet Connection Configuration.
Click on disconnect, if this does not work it may be necessary to remove the DSL cable.
Enter your correct username <your username>@plusdsl.net and password.
Plug in DSL cable (if removed) and click on Connect
Check your Hub One has logged on to the correct Broadband Username
Tbalderstone1
Okay I’ve just checked and yes it is setup@plusnetdsl.net
I will attempt a factory reset and leave it for 10 and get back to you👍
Fixes: 528
I'm afraid that's not going to help, John. There's no DSL sync!
@Tbalderstone1
is your Hub connected to the master socket ?
Do you have a master socket with separate Phone & ADSL ports ?
You've obviously got some other means of internet access as you are posting here , so have a look at the help pages here https://www.plus.net/help/broadband/connection-troubleshooting/
Tbalderstone1
It’s a 5c master socket - it’s a single socket but I have the filter but for phone/broadband
Fixes: 334
OOPS - that booster jab must have addled my brain. Apologies, @Tbalderstone1
Fixes: 528
Ok, its probably worth removing the faceplate and connecting to the test socket behind it, just in case, but to me it sounds like Openreach havent connected you to ADSL properly.
Does your phone work ok ?
