Still having outage problems
- Still having outage problems
- « Previous
- Next »
Re: Still having outage problems
22-09-2014 8:33 PM
A simple solution to the HHID functionality challenges might be to use RouterStats to obtain the Modem Stats.
The summary tab shows the DSL stats and thus might be a simpler route to grabbing them rather than negotiating the router GUI. Big right panel - select all (CTRL-A) - copy (CTRL-C) - paste it somewhere (email?) (CTRL-P).
Kevin
26-09-2014 10:58 AM
Husband hadn't chucked the laptop through the window, but came close. Colleagues found it quite amusing listening to me trying to give him instructions
Graphs are pretty boring, didn't spot anything significant so here's the summary:
xdsl info expand=enabled
Physical Layer Statistics:
Modem state: up
Up time (Days hh:mm:ss): 7 days, 23:28:58 (well happy!!!)
xDSL Standard: ITU-T G.992.5
xDSL Annex: Annex A
Channel Mode: Interleaved
Number of reset: 7
Chipset Vendor info (G.994.1): Local Remote
Country code: B500 B500
Specific: 0000 71C8
System Vendor info (showtime): Local Remote
Country code: 0F00 0000
Specific: 3C61 0000
Bearers generic info DS US
Payload rate [Kbps]: 14328 888
Attenuation [dB]: 28.0 14.3
Margins [dB]: 10.1 16.4
Output power [dBm]: 0.0 12.4
Number of bearers: 1
Bearer 0 DS US
INP [DMT symbols]: 2.90 2.00
Delay [ms]: 6.70 8.00
Depth []: 416 0.00
R: 8 0
G.997.1 Statistics (Current):
Failures:
Line failures Near end
Loss of signal (LOS): 7
Loss of frame (LOF): 60
Loss of power (LPR): 0
Performance monitoring:
Line PM: Near end
Error second (ES): 116
Channel PM: Near end Far end
Bearer 0:
Code Violation (CV): 37 7
FEC: 491974 1685
ATM data path PM: Near end Far end
Bearer 0:
HEC violation count (HEC): 409 N/A
G.997.1 Statistics (last 15 minutes):
Failures:
Loss of signal (LOS): 0
Loss of frame (LOF): 0
Line PM: Near end
Error second (ES): 0
Bearer 0:
FEC: 491974 1685
Bearer 0:
G.997.1 Statistics (last 24 hours):
Failures:
Line PM: Near end
Bearer 0:
FEC: 491974 1685
Bearer 0:
{admin}=
So I reckon a new training period could be in order?
Can someone from Plusnet CRT check this out for me please?
27-09-2014 3:21 PM
This is the same xDSL session as that started on 18th Sept, by the looks of things around midday. Only 10 error end seconds on the last 5 days is really good.
If the RouterStats graphs are dead flat, it could be the case that the target SNRM is (was if the DLM has acted on the improved stability) 9dB. One way to determine this for yourself would be to do a graceful restart (manually drop PPP wait a couple of minutes and power off the router for 10 minutes. Power up and see what the stats say. You might need to manually force a PPP reconnect.
If the SNRM is circa 6dB then you do not need CRT intervention.
27-09-2014 5:03 PM
I've included the latest graph for you to peruse.
27-09-2014 5:12 PM
If it had been midnight, I could have explained the change away with evening AM radio continental interference - the only residual explanation is that there was some REIN around at that time. Keeping the graphing running for the time being would be really useful.
Kevin
28-09-2014 12:04 PM
1. Manually drop PPP wait a couple of minutes and power off the router for 10 minutes.
2. Power up
Stats as follows:
Modem state: up
Up time (Days hh:mm:ss): 0 days, 2:00:41
xDSL Annex: Annex A
Number of reset: 0
Specific: 0000 71C8
Specific: 3C61 0000
Attenuation [dB]: 28.5 14.2
Margins [dB]: 9.8 16.3
Output power [dBm]: 0.0 12.5
Bearer 0 DS US
Depth []: 416 0.00
R: 8 0
Failures:
Line PM: Near end
Bearer 0:
Code Violation (CV): 0 0
FEC: 1613 0
Bearer 0:
HEC violation count (HEC): 0 N/A
Failures:
Line PM: Near end
Bearer 0:
FEC: 1613 0
Bearer 0:
Failures:
Line PM: Near end
Bearer 0:
FEC: 1613 0
Bearer 0:
{admin}=
From what I can see there is little change from the last stats I posted. So it appears that I am "glued" to 9db or thereabouts. OK... I know the stats are only 2 hours old but I'm loving those 0's !!!
I guess that I will have to make a request to the CRT for a reset?
28-09-2014 12:18 PM
Your line is though still on the margin. If it would remain stable at 6dB it is not likely to quite reach the expected 16Mbps.
You've choices here, bite the bullet and request a DLM / SNRM reset and see how things go over the 10 day training period or wait and see.
Which ever route you take, please keep RouterStats running. You might care to play with the alarm settings on SNRM variability to alert you to an event.
Cheers,
Kevin
28-09-2014 12:31 PM
I'll keep monitoring for the rest of this week, then I might take the plunge and ask for a reset on Friday (and maybe regret it )
You can have some peace and quiet from me, Kevin.
Thank you for all your help (so far)
29-09-2014 2:09 PM
Glad to see that things are looking better!
If you do decide to go with the SNR Reset then please let me know via DM and I'll be more than happy to get the order placed for you.
- « Previous
- Next »
