Still getting slow speeds
- Re: Still getting slow speeds
15-01-2013 1:51 PM
The recent SNR reset has made no real difference to my speeds.
Connection is rock-solid (apart from a manual reset about 3 days ago) but my sync rate is stuck in the 14000s.
Message 1 of 5
(727 Views)
4 REPLIES 4
15-01-2013 2:21 PM
I'll try that again for you, I'd definitely agree that the line is stable at present. I can see that the SNR margin is already around the 6db mark so definitely time to raise a fault if this reset doesn't help.
Message 2 of 5
(407 Views)
15-01-2013 2:43 PM
Thanks Adam, you're very kind!
How long will it take? Will it resync to let me know it went through?
Message 3 of 5
(407 Views)
15-01-2013 2:47 PM
Message 4 of 5
(407 Views)
15-01-2013 2:53 PM
It's always been my experience that if the target SNR changes, you'll get a resync, though since in this case it's not actually changing, you may well not.
I do find it strange though that you have lower sync than I do even though I seemingly have a longer line (based solely on attenuation figures).
Message 5 of 5
(407 Views)
