Still fast path and the ping has shot up - help
- Re: Still fast path and the ping has shot up - hel...
04-01-2012 9:08 PM
As per the title, its still showing as fast path on my router but the ping has shot up around 50ms making my gaming poor once again.
I don't know if there could be damage to the exchange or something due to the severe winds up this way but can someone check it out as its playing like im interleaved again even though I can see I am not.
Terry
Terry
Message 1 of 6
(1,526 Views)
5 REPLIES 5
Re: Still fast path and the ping has shot up - help
05-01-2012 1:38 PM
Hi TerryCTR,
It may be something to do with this. I'd be interested to see how it goes tonight after we increase network capacity.
Jojo
Jojo
Message 2 of 6
(627 Views)
05-01-2012 4:34 PM
Hi Terry
If the pings & latency increase again, post some pings (-n 100 should do) & tracert's to the bbc.co.uk & google.co.uk to see if anything stands out http://www.plus.net/support/broadband/troubleshooting/running_ping_tracert.shtml
Also if you've got a static IP the tool on think broadband is very useful for latency
http://www.thinkbroadband.com/ping
Cheers f9o
Cheers f9o
Message 3 of 6
(627 Views)
05-01-2012 11:35 PM
Jojo I havent played tonight being floored with the man flu going about but I will try tomorrow and check it out. I don't really know what the 20 to 21cn stuff means but I stumbled on something that said I could get a bt
Infinity line to 20 meg by June of this year.
Does this mean my connection would get better with you as it seems the ping still wouldn't be great with bt capping.
Force- thanks for the info I will check it out tomorrow and run some tests if its still lagging.
Terry
Terry
Message 4 of 6
(627 Views)
07-01-2012 5:46 PM
Seems to have sorted itself out and the ping is back down where it should be again.
Can you confirm if bt upgrade my line by June that the ping would drop further?
Terry
Terry
Message 5 of 6
(627 Views)
09-01-2012 2:45 PM
Hi Terry,
I don't think we could confirm that the ping would drop for you. If the line quality improves then yes it probably would do but that's not something we can guarantee at all I'm afraid, please also bear in mind that a faster line speed doesn't necessarily mean a better quality line.
Message 6 of 6
(627 Views)
