Still dropping connections after 3 months and 3 Openreach visits!
- Still dropping connections after 3 months and 3 Op...
20-08-2009 9:42 AM
After steady connections for 3 years, speeds dropped to 250K, leading to fault initiation. Usual steps undertaken (several times now)-test socket, different modems, faceplate, ring wire etc. Speed got up to 1.1M but would then unpredictably crash down again, taking the usual 3 days to recover (even in test socket). PN see dropped connections and resyncs, so Openreach appointments made.
3 visits, each unique in their own way. 1st guy tested the line at the exchange and master socket, got 3.6M sync rate and did little else (I can get this on modem startup, but it drops after a variable, but fairly short time). 2nd visit, thorough line checks, no errors, synching at 2.9M. This one rewired master socket to the upstairs study and made the hall one an extension, fitted BT split faceplate and left with my modem synching at 3.1M. Within 30 mins, it had dropped to 500K. Improved to 1.1M during the week but PN still seeing drops, so visit number 3. This one removed the faceplates, made the downstairs socket the master again, and refitted my ADSL filters to each extension. Also got the line gain turned up, even though the quiet line tests were silent. He left with my modem synching at 2.3M, which lasted about an hour-back to 1.5M last night, but PN profile set at 750K.
My line? Underground cable. Reports 3.8km to the exchange even though KItz.co.uk makes it 2.7 by road and 1.7 direct. Downstream attenuation of 52-56dB, SNR anything from 4 to 19 dB, usually between 12 and 15 dB. Should be capable of 2-3M at least?
Have I run out of options? I'm on the verge of going with mobile broadband!
Re: Still dropping connections after 3 months and 3 Openreach visits!
20-08-2009 10:00 AM
Sorry to hear you haven't had much luck getting BT Engineers to sort out your problem
In your last ticket reply you stated "Engineer visit complete-he reversed most of the changes made last week. Had the line gain turned up as well. Will shortly reconnect to the master socket and see what results." What was the stability like in your test socket before you moved back to the master socket? Or when you were saying that did you already mean that you were connecting to the test socket?
20-08-2009 10:02 AM
20-08-2009 10:59 AM
To Reed Richards-have used 3 different routers, my original PN Voyager 2100, a new Linksys 160N (most unstable with this one), and the ZyXEL 660HW-D1 which gave the most stable ongoing connection, and picks up the line itself when it drops, rather than me having to reconnect.
20-08-2009 11:01 AM
I'd be interested to see, if possible, if you could stay plugged into the test socket throughout the course of the weekend and see if the speed and stability of your connection remain.
If not (especially if there are connection drops) then we'll need to get BT out again
20-08-2009 12:32 PM
I suppose you're familiar with the fact that BT don't seem to keep a record of previous issues, as I've had to explain the whole problem to them every time.....
20-08-2009 2:21 PM
Quote from: SteveE To Reed Richards-have used 3 different routers, my original PN Voyager 2100, a new Linksys 160N (most unstable with this one), and the ZyXEL 660HW-D1 which gave the most stable ongoing connection, and picks up the line itself when it drops, rather than me having to reconnect.
All routers should re-establish the connection automatically if it drops, although you can often turn off this feature. Re-establishing the connection is almost always the default option (although I remember an old Belkin router it was not).
20-08-2009 7:13 PM
24-08-2009 11:30 AM
My SNR is also still all over the place, varying from 1 dB to a more common 15 db, with other values in between. I had asked for data on how many dropped connections I was having over the weekend-does the reply I got suggest they weren't seeing any when I was in the master socket?
Still no further forward really....
24-08-2009 11:49 AM
24-08-2009 12:17 PM
24-08-2009 1:38 PM
To jayed: My experience seems very similar to yours-I'd never noticed problems until May, and since then it's been up and down regularly. When stable, it holds 1100 or so, then drops without warning to 250 or even less. 3 days later, usually back to 1100. It's the unpredictable part that's most annoying.
I've been with PN for more than 7 years, but not enjoying the current experience (although support have been helpful and persistent).
24-08-2009 1:59 PM
The way the target is used is that each time you sync the exchange and your router negotiate to find the fastest speed they can connect at while staying at or above the target noise margin. The noise margin will vary during the day, during the evening particularly it will go down due to increased interference. Your changing things around last night probably meant you reconnected at the worst time.
24-08-2009 7:04 PM
28-08-2009 3:36 PM
Router etc still plugged in via ADSL split faceplate, no other changes to phones etc.
I'm losing the plot.....
