Steam Downloads
theberrys
Steam Downloads
Hey folks Smiley
I have recently started to re download my Steam library after my operating system decided to go kaput  Roll eyes
The only problem I have is the speed.  Every time I go on Steam, the best speed I see is about 200.0KB/s Sad  Other downloads are fine and download at about 650 - 700KB/s, it is just Steam that doesn't want to download at those speeds.  Is it that Steam downloads get limited?  Is it traffic management?
I am on Plusnet Unlimited btw Smiley.
Fixes: 62
Re: Steam Downloads
I have never found the Steam downloads to be limited
theberrys
Re: Steam Downloads
This is a screenshot of Steam downloading COD 4:
I have tried changing download servers but it doesn't change anything Sad
theberrys
Re: Steam Downloads
Aha!  I think I fixed it.  In the settings, I changed the "approximate speed of your internet connection" to  DSL/Cable > 2M.
Fixes: 62
Re: Steam Downloads
Mine was set at  >256kbps and I was getting speeds in excess of 400kB/sec which is my full line speed
theberrys
Re: Steam Downloads
It has just slowed right down again Sad  I don't know what it could be Sad
Fixes: 71
Re: Steam Downloads
Aren't downloads (from content servers) on the Unlimited product limited to 2Mbps (250kB/s) until midnight?
David
theberrys
Re: Steam Downloads
If that is true, is there any way to ask plusnet to remove the restriction or will I have to move products?
Fixes: 62
Re: Steam Downloads
They also are on Value but my download was still at full speed
theberrys
Re: Steam Downloads
Still downloading at 240KB/s Sad  Can anyone from plusnet support see whats up?
Epyon
Re: Steam Downloads
Change you're location to netherlands
always works for me when getting poor speeds.
theberrys
Re: Steam Downloads
That hasn't affected the speed Sad
dick:quote
jojopillo
Re: Steam Downloads
Hi theberrys,
Steam should run at line speed. We've just been testing it and we get line speed. Is it wired or wireless? Is someone else using your network at the same time? Is something else running on your computer at the same time?
Jojo Smiley
Fixes: 103
Re: Steam Downloads
Might be an idea to check using a local bandwidth monitor (like this one). That will tell you what your cumulative bandwidth is to/from the machine it's installed on. If that's maxing out at line speed but steam still shows ~200kB/s download speeds then something else must be using the connection.
FWIW, I've just opened Steam on my home machine and it started downloading three game updates at line speed (Extra)...
theberrys
Re: Steam Downloads
Yes, but that shouldn't affect it.  I tried downloading kaspersky antivirus trial and I got max speed (~600KB/s)
Just me on at the moment.
I shut down all other programs open that would access the internet.
Cheers
When I stated a steam download yesterday,  for 5 minutes it is at 600KB/s and then it drops down to 200KB/s for the rest of the time
