Stays of service in KT13
Paulk37
My broadband service is very intermittent. Oatlands in weybridge. Is there a problem?
6 REPLIES 6
Aspiring Legend
Fixes: 194
Re: Stays of service in KT13
@Paulk37 It may be just your connection. Are you on an ADSL or FTTC connection, as that will influence the advice other Community members can offer?
Paulk37
Hi john thanks for your response.
it cleared itself by 19.00. i am on adsl. might just have been a heavy loading period.
afternoons the service is generally up and down.
thx again
Paul
Aspiring Legend
Fixes: 194
OK Paul. If it's up & down, might be worth having a quick look. If you wish, I will post the standard guide I have for this.
Paulk37
Yes please. thank you.
Aspiring Legend
Fixes: 194
OK - will do in a short while, visitor at the moment.
Aspiring Legend
Fixes: 194
@Paulk37  A good starting point is to have a look at This post and supply as much detail from it as possible.
It would also be a good idea to carry out a 'Quiet Line Test' - dial 17070 from a (preferably corded) phone and select option 2 - there should be no discernable noise.
I suggest you do the Quiet Line Test first, to eliminate voice line faults, as that needs clearing before we can look at the broadband side.
Any queries, don't hesitate to post back.
