Stats: Any Room for Improvement?
- Stats: Any Room for Improvement?
10-12-2011 4:46 PM
Re: Stats: Any Room for Improvement?
10-12-2011 5:07 PM
If your sync rate is 5664 kbps then the IP Profile (throttle) applied to your line is 4500 kbps. If you could sync at 5696 kbps then your IP Profile would go up to 5000 kbps. Unless you're on ADSL2+ in which case other rules apply.
10-12-2011 5:09 PM
Quote from: ReedRichards Unless you're on ADSL2+ in which case other rules apply.
I am on ADSL1. I use a filtered faceplate and I am connected to the master socket. Is there anything I can do to stop the connection disconnecting? I presume the disconnections increased the target SNR to 9dB?
10-12-2011 6:30 PM
Quote from: sjrinfroyle Is there anything I can do to stop the connection disconnecting?
There's not a lot you can do.
If there is any audible noise on your phone line you should report this as a phone line fault and try to get it fixed. You could try to look for any pattern in the disconnections. If your line appears stable you could ask for it to be reset.
10-12-2011 6:33 PM
If so you could try the test socket - during the daylight hours - and see if the speed improves and the disconnections stop
Also, if there are any other sockets in the house, how many wires are connected to the removable faceplate - there should only be two on terminals 2 and 5
Have a read here http://www.kitz.co.uk/adsl/socket.htm
10-12-2011 6:51 PM
To answer your questions:
Do you have any other sockets in the house fed from the filtered faceplate. - I have two other sockets.
If so you could try the test socket - during the daylight hours - and see if the speed improves and the disconnections stop - I have tried the test socket before and it didn't make any difference.
Also, if there are any other sockets in the house, how many wires are connected to the removable faceplate - there should only be two on terminals 2 and 5 - Terminals 2 and 5 are the only wires connected to all of the sockets and the faceplate.
Somebody has suggested a "Lift and Shift" which would move me onto another pair but I think Plusnet would be unwilling to do this.
10-12-2011 7:01 PM
At least the speed is good enough to run iPlayer on HD which mine didn't used to be
You could of course try a router where you can manually tweak the noise margin and see if you can push the speed up to over 5696kbps which will give you a 5,000kbps profile.
Probably a 1db reduction will give you that.
However if you have a resync in the middle of the night that will undo all the good work.
It is always possible a different router will give better speeds as well. Which one are you using at present
10-12-2011 7:06 PM
Quote from: Oldjim It is always possible a different router will give better speeds as well. Which one are you using at present
Netgear DG834GT.
10-12-2011 7:09 PM
10-12-2011 7:12 PM
So it is both a software change and a physical change at the exchange.
A new pair can either refer to the D side - ie from the cabinet to your house connection point (usually telegraph pole joint point)
or to the E side - that part of your line from the exchange to the cabinet.
...and it means your line is swapped to a spare line pair in either/or/both the D side and E sides (assuming there are any spare pairs available - more of a problem usually on the D side)
10-12-2011 7:30 PM
Quote from: x47c A lift and shift is where your connection is changed to a new line card at the exchange
Could it help with my problems?
10-12-2011 7:35 PM
10-12-2011 7:39 PM
It depends where the problem is.
Have you tried monitoring continuously and see what happens to noise margin and error rates over night and when the disconnections occur
This is the sort of thing you can get
The first picture is noise margin
The second picture is the uncorrected errors every 15 mins
10-12-2011 7:41 PM
Thanks.
10-12-2011 7:46 PM
